TriHonu, I stumbled across this site the other day. WOW!! I can't believe how much info you guys have here. I'm currently trying to make a mount for a plow. I really like your mounts that you made. I have a couple of questions. 1) How has it held up? 2) I noticed the lack of a lift chain. Does it put extra stress on the arms? 3) This is the most important for me. Can you give me some measurements off the brackets? I'd love to copy you if you don't mind. Thanks, Joe
Just saw your post.
1. It has held up just fine. I qualify this statement with the fact that I don't use it to slam into frozen piles, curbs, etc.
2. No, it puts less stress on the arms than full bucket of dirt. I had a little concern that the attachment plate could bend where the large angle is welded across the plate. The angle has done its job and the plate show no sign of bending.
3. I went out to the shop and dug through my pattern files. (I make cardboard templates for many of my projects.) I found the templates and will try to sketch them and put some dimensions on them. The three sets of holes were placed to allow for specific amounts of float at the cutting edge. So the distance and angle of the holes in relation to the pivot bolt is dependent on the distance from the pivot bolt to the cutting edge.
The other dimension you have to take into account is the how high the plow pivot bolts are supposed to be from the ground (manufactures specs). This will determine the angle of the cutting edge to the ground. If you put the arm pivots too high off the ground, the cutting edge will tend to want to dig in. If set too low, the plow will want to ride up on top of the hard pack. My design allows for float in two directions and still allows you to roll the quick-attach forward to force the cutting edge down as needed.
