Slow moving Boxer 530x
mikaelmeir
Started my Skid steer after winter but Moves very slow (bucket speed is ok) when I shift it to high speed no change and it almost kills the engine. changed the engine oil and filter, made sure enough Hydrolics and ..... Was just fine before winter ! appreciate any information. I got two of them and one is just fine like before .
tech.35058
Greetings Mike ... I know this is an extremely ancient post, but do you still have the boxers? Did you find an answer? I have a Mertz boxer tl224. currently when I "dead head" the aux hyd circiut, it stalls the engine. ( I have an accessory with a device mounted "open/close" valve. If I am going to use it I need to figure something out.) do these things have a relief valve on this circuit? what is it supposed to open at? where is it? I have operators manual & parts manual. service info is pretty sketchy. any info is appreciated thanks, CE
CharleyB
did you ever figure it out? My Boxer stalls out, even at full throttle, when i try to engage the aux togggle lever.. its like the pressure cant go anywhere and it immediately cuts the engine.. any info appreciated. Thanks
CharleyB
