New Holland C238 Codes
DJM!
I got a new to me C238, came in with some codes, after drying off in shop they when away. Today didnt get an hour out of the machine and it threw the following codes.
5122 boom raise/lower: pin B short to power/ short to ground/ open circuit
5134 Bucket rollback/dump: Pin b short to ground/open circuit
5202 boom raise/lower: pin B short to power/ short to ground/open circuit
ground drive: pin B short to power/short to ground/open circuit
5214 ground drive: pin B short to ground/ open circuit
5501 boom raise/lower: sensor short to ground/open circuit
5504 bucket rollback/dump: sensor short to power
5512bucket rollback/dump: implausible state sensor versus loader bucket command
5513 aux control function: implausible state sensor versus auxiliary command
1905 power supply: 5VREF1 sensor supply voltage out of range
where is plug that is coming loose?
Thank you
brdgbldr
They may not be coming loose. It could be that you have water in one or several connections. You could also have a rub through somewhere that grounds out when wet or when the machine vibrates it to ground.
I hate electrical problems.
I would start by disconnecting the connections one at a time and blowing them dry and the hitting them with an electrical contact cleaner before hooking them back up. While doing this keep a lookout for rub throughs.
