I have a L 553 with neutralizer problems. I tried adjusting the control levers according to the service manual. Removed the end play on both neutralizers-no problem. Loosened retaining bolts(rear end on the right one-front end on the left one) Wheels were creeping rearward. Could not make any adjustment. I tightened the bolts back up. Didn't seem to be any slots there. The front bracket on the left neutralizer under the seat is slotted. I adjusted it there and it worked fine. Adjusted the left neutralizer with the end play bolts. Got the wheels to stop creeping. However the levers need a little help returning to the neutral position. seems the springs are a little weak. Is time to rebuild the neutralizers and do I replace the shock absorbers also. Any help would be appreciated
