OldMachinist
- Joined
- May 24, 2006
- Messages
- 2,748
I used to have this hanging on the wall in the shop and I found it while I was going thru a bunch of files I brought home when I retired, just thought you might get a chuckle out of it. Someone gave it to me many many years ago.
Recommendations to eliminate
Misteaks in the shop
1. When changing cutting tools on a machine, It is generally quicker to turn the machine off first
2. Large ultrasonic cleaning machines shall not be used for bathing. Showers although requiring soap and a little effort, are safer.
3. Much time can be save by not using left handed wrenches on right handed nuts.
4. In the future machining wire from bar stock must stop.
5. Attention must be paid to all drawings and prints. Note that they have two sides. Use the side which has the brighter image.
6. Charging batteries from the AC electrical line will not be permitted except when a battery charger is used.
7. The pointed end of a drill bit should face the work. Not only will this reduce the number of broken bits, but the work will go much faster.
8. When using cutting oil a cutting tool must also be used. The oil will not do the job alone.
9. The practice of using micrometers as c-clamps must stop, especially on welding fixtures where the splatter can mess up the numbers.
10. Work that has been heat-treated or welded should not be handled until after the red color is gone.
11. Be sure that all shipping address labels are on the outside of the box.
12. When using a welding helmets, Note that the dark glass window should face front not to the rear.
13. Dueling with forklift trucks will be discontinued immediately.
14. During the use of a cutting tool, if no chips are seen coming off the edge of the cutter, It is usually caused by one or more of the following reasons.
A. The cutter is dull
B. the cutter is upside down.
C. the cutter is not touching the work.
D. the machine is not turned on.
