ls180 how to lift boom
patl
My starter is out and i need the boom up to replace it. I have opened the hydr. lines on each cylinder and still nothing.
P
patl
i imagine there is a valve that has to be bypassed or opened but i cant find it to save my life. any information would be greatly appreciated.
Mike10
Unpin the rod end of the lift cylinders and use another loader to raise the boom until you can engage the boom locks. You can also install a hose into the bottom outside port of the lift cylinder, remove the line at the top of the lift cylinder and use another source of hyd flow such as skid loader, tractor, pump. You will need to put a bucket under the removed line and also the top port of the cylinder because as you raise the loader oil will flow out of each.
