I have an LS170 & LS160 New Holland so I can test with the other machine. I believe both are in the 2002 year range. The LS170 a few weeks ago would not turn over or click and the lights on the EIC were dim. The battery was 6 years old so I just ran out and bought a new one, cleaned both positive and negative cables to the starter and bell housing and checked the ground cable from starter to frame. It was working great until two weeks later I hop in it and the Dash was Dim again. I put the RUN/SERVICE switch into Service position and turned the key with nothing happening, not even the EIC would light up. Flipped it back into the RUN position while sitting in the seat, dash was dim again and no clicking or fuel pump when I turn the ignition, just the EIC lights go really dim. I checked the 5amp and 15 amp fuses in the engine compartment and the 5 amp fuse next to the RUN/SERVICE switch. They are all good. Seat Switch and belt buckle switch have 12 volt at them along with everything else in the system. What I noticed is when the seat switch is activated it drops form 12 volts down to 5 volts along with the Red/White wire at the ignition switch and the main fuse block in the engine compartment. once I deactivate the seat switch everything goes back to 12 Volt. Could this be the Interlock Relay? If not what should I check? I have a service manual. Thank you so very much in advance as our farm cannot afford to ship this machine off to the dealer right now so I am willing to troubleshoot all week if I have to. This machine has 4100 hours on it.
