Does yours have the electrical lockout solenoids on the control valve? If so check for power at all of them , if they all have power remove the boom one and put a plug in the hole temporarily. I would guess you can bench test it with 12v power to see if it moves or is stuck. If not the solenoid and it gets power I have no idea. With the solenoid out the valve should move but don't run it that way because of the safety issue of people lifting the boom , stepping out of the cab and accidently hitting the pedal. Bad things would happpen very quick.
