Can't reply to posts - HELP???
twinwillows
When trying to reply to posts I keep getting this error message. What's wrong??
Server Error in '/' Application.
Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails. Cannot insert the value NULL into column 'TotalPosts', table 'BobcatDNN.dbo.AdverFRM_Forums'; column does not allow nulls. UPDATE fails. The statement has been terminated. The statement has been terminated.
[FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Exception: Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails. Cannot insert the value NULL into column 'TotalPosts', table 'BobcatDNN.dbo.AdverFRM_Forums'; column does not allow nulls. UPDATE fails. The statement has been terminated. The statement has been terminated.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
Code:
[Exception: Cannot insert the value NULL into column 'PinnedDate', table 'BobcatDNN.dbo.AdverFRM_Posts'; column does not allow nulls. INSERT fails.
The statement has been terminated.]
   AspNetForums.Data.SqlDataProvider.AddPost(Post postToAdd, String username) +1019
   AspNetForums.Posts.AddPost(Post postToAdd) +101
   AspNetForums.Controls.CreateEditPost.PostButton_Click(Object sender, EventArgs e) +1566
   System.Web.UI.WebControls.Button.OnClick(EventArgs e) +108
   System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +57
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +18
   System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +33
   System.Web.UI.Page.ProcessRequestMain() +1292
Version Information: Microsoft .NET Framework Version:1.1.4322.2300; ASP.NET Version:1.1.4322.2300 [/FONT]
Does this happen every time? i get it every so often, but rare.
What web browser do you use? it really doesn't play nice with firefox (till the new version of the forum is released) its happy using internet explorer though.
skidsteer.ca
I have had that one a few times the last week or so, but with a try or two it usually works. not sure why this happens, I make it a point to copy what I type before I hit "post"
owensge
Which post where you trying to reply to? Yes, what browser please. I definitely want to know about these kind of errors.
skidsteer.ca
I have had it with IE 7, does not seem to be any certain post, just happens once in a while, usually after I was quite long winded...
What should we be looking for to tell you? Cut and past the error as above?
owensge
Yes, that's what I need. Are you still able to do the post or do you have to start over?
skidsteer.ca
My experience is just hitting the back button won't work and the text is all gone anyway. Usually going back to the "reply" button in the thread will work.
I'll try to make apoint of posting any error here
Fishfiles
Don't know if this helps but could it be a "timing out issue " , for sometimes I start a post or reply and go do something else and come back a while later and it doesn't go thru as if you got a time limit to perform the action or you dropped or canceled?!?
