BOXER 700HDX
Esugar
Hello, any ideas on why my Boxer 700hdx diesel runs for 15 mins then shuts off. I let it sit for 5 mins then it will start back up, takes a little more cranking to start up though. I checked the fluids, not sure where else to go with it? Any help would be appreciated.
brdgbldr
I am not familiar with that machine but it sounds to me like fuel is shutting off. Then the remaining fuel gets used before the engine stops. Then when you go to restart it the fuel system has to pressurize before it will restart.
Just my guess.
foton
I am not familair with that unit either but if it has a manual primer bulb in the fuel circuit ,pump it up to see if it gets hard . If it does not you might have a vacuum problem between it and the fuel tank.
thwerench
Had a John Deere tractor once with the exact symptoms and found the fuel filter was plugged
