Bobcat 753 c series
zanebrandt
Hey I have a bobcat 753 c series older one I have hp-1 and hp-2 code I replaced the inline filter that connects directly to the hydraulic tank I also got a hydraulic pressure switch from bobcat but for the life of me can't figure out where it goes any help would be much appreciate.... also the only spot on the machine that I found a switch that looks identical is on the back side of the air intake filter housing is
Tlawdogg
Check out Bobcats website. Put in your model and narrow the search with that serial (P.I.N.) number. Then you can look at your machines schematic. Find where the pressure switch should be.
Just a note, see if you have TWO hydraulic in-line filters. You mentioned you changed or cleaned One. Usually TWO on those skidsteers. I see TWO on your schematic. Items #31.
Z
zanebrandt
Yeah I looked at the bobcat website just kinda hard to read and yes I did find the other inline filter but figured the one I changed was the one that absolutely needed it I'm replacing the switch on the back side of the air box now to see if that has anything to do with it like I said they are exactly the same so we will see next I could change the hydraulic filter itself but my dad said he just did that not to long ago
