Bobcat 753 will start won’t move
JohnP98
at work our bobcat will start and the hydraulics work when the bar is down, but it won't go forward or backwards. You move a couple inches and everything starts to stall out not sure how to fix the problem
brdgbldr
Just a shot, your brake may not be disengaging.
RedNeckMike
If it is parked on a slope or grade of any kind there is more pressure on brake to try and release especially if brake solenoid is weak. Rock it back and forth brake may release. If it does then park on flat ground each time until you get it serviced.
WVRoger
On your computer board in the earlier models you were required to have four lights showing green to operate the machine. Sounds like you may have a solenoid sticking or your computer has a difficulty!
