Brianclements
- Joined
- Apr 22, 2016
- Messages
- 6
I have a older 743 that set up for a couple of years with a blown engine. It worked as it should before the engine problem. I put a new engine in it and now it has no power as far as pushing or turning. I checked the charge pressure and it is 100psi but when I try to turn or drive it drops to 10psi. I pulled the engine pumps and all the lines and valves and found no problems. I also tore the charge pump down its a vickers vain pump. It had a lot of ripples wore in it where the vanes run I smoothed them down and reinstall it but no change. Would you say that pump is just gone and not holding the load of the hydrostatic pump?
