I've spend a few hours reading any posts I can find on the subject and still haven't been able to get the drive sheave removed from the motor. I've removed all of the outer hydraulic bits and am down to just the sheave attached to the motor. I've remove the bolt from the center and have installed a different bolt with the center countersunk. I have put 2 bolts on the two holes on the sheave and a bearing splitter over those and then used a 3 jaw puller to attempt to pull the sheave with not luck. I just end up shearing off the bolt heads. I've tried putting pressure on the puller then hitting the end with a hammer, I've tried tapping up and down on the sheave with a deadblow, I've soaked everything in penetrating oil, even turned the sheave so the keyway was up,made a plug for the outside of the sheave and filled it with penetrating oil and let it soak for a week. Is there something I'm doing wrong or is it just that rusted?
