This is what i do, if its rite or not i don't know, its your choice i don't want to get in trouble for telling you to do something that causes any damage.
With that out of the way:
I pull the injectors out (naturally) hold them rite way up in a vise and remove the nut at the top of the body. This will allow you to disassemble the injector. Ensure you keep ALL the parts from each injector separate!!! Remove all the pieces and sit them in a plastic container. You will get to the nozzle, this is the business end of the injector. There is a plunger that sits in the body, this must be free to move in and out. When an engine has been sitting for a while they can actually get stuck. If its tight use the vise to hold onto the pin at the base, be careful not to knock the tip as its very delicate and can be easily broken if knocked. With holding the base of the nozzle in the vise see if you can twist the outer part to get it free, if not you can use a screw driver to lever it up. When you get it out, use say WD40 and move it in and out till it feels smooth. Take all the parts out and clean with kero or WD40. Where the spring came out of the housing there will be a few flat spacers tucked away, when you are blowing the injectors out they may come loose, be careful not to loose them as they set the cracking pressure (when the injector opens up). I re-assemble using WD40, make sure the nozzle runs free and smooth in its housing. Pull all the parts back in the way way they came out. It should be good to go.
Hopefully you will find a stuck nozzle, if you do thats your answer to the problem.
Does that all make sense?
