a/c temp knob working backwards s205
7LBSSMALLIE
red cold ,blue hot ,new heater valve . wires traced tried switching wires around feel stupid anyone?
7LBSSMALLIE
i am afraid it may have been this way before i started . all i could tewll was a/c not blowing cold, never thought to change direction of knob, all i know is heater valve seemed to be by passing both hoses hot, replaced valve same same . has the jumper harness. wires correct. valve workinking proprely porpotinal as well just backwards, feeling awufally stupid, any help. yes did try red to black swap ads well as red to white or combitions of same.(unit needed to leave) told customer its backwards made labels but driving me nuts, sending one out this way is not what we do. got two hrs into with no joy. i did put old valve in where i could see it to confirm switch to red open switch to blue closed (potentiemoter) was under the gun ,but why
Bobcatdan
I don't know, swith install someway that is was rotating wrong, knob not on right? Real strecthes I know. If I ran into this, I would have tired a different valve. Being a bobcat tech, I'm sure you think real highly of bobcat qc. I don't know, can the motor be put on upside down?
7LBSSMALLIE
nice may have been hadnt thought of that still out there running ac blowing cold. but i got no answer cust ok , but still bugs me .ill see it again with more time to t/s
7LBSSMALLIE
as to qc they try.getting pretty tight with accountably. if gerado inspected it before it left factory , and i do p/d and has warr issues they want to know. for the most part they are comming in tight. accountabbly is paroumount. off the lineinspected goes to final and than us and we pick em apart, new pd . at dealer level is compresive wrong post for a disserattion though
7LBSSMALLIE
this unit is still out working and running cold.(issue still not found)
SkidRoe
6 MONTHS LATER STILL WORKING THIS CASE CAN BE CLOSED THANKS..
Don't feel bad. We put out equipment that costs $1.5-2 million each with a second plant in an alternate location (cheap labour) doing assembly as well.
The machines coming out of our plant are pretty much turn key (if they had keys) after PDI. The other plant's machines: 2-3 days of solid work by 3-4 techs to make them deliverable to the customer.
Sad.
7LBSSMALLIE
Sad.
it is sad, granted we all screw up and miss things, we try our best not to ,but mistakes happen,thats life, but being able to trust our compatriots, ? SAD, I SUPPOSE MY DEFITION OF SQUARED AWAY. may be somewhat different than others, for me it means im not chasining it, no mud on my face.
As long as it blows cold air and the customer is happy, your job is done.
