Guys, my auxiliary hydraulic switch doesnt work all of a sudden. Is there a fuse or mechanical reason why the switch no longer lights up or turn on aux hydraulics?
There should be fuses in the engine compartment. Typically the Fuse marked PWM or AUX is for the auxiliaries. If the fuse blows again check the wiring harness for chafing...the controller for the auxiliaries should be located on the underside of the cab, behind the seat(near the cab tilt hinges).
