2016 T650 error code MO309 Low Voltage
mclark
Hello all, Hey I need to know where and what to check. Battery is charged up. Starter cranks good. Checked all fuses , their good. Squeezed fuel bulb and can feel fuel. ALJG19580
foton
take a meter and test the battery with the engine not running, should be like 12.2volts or so. then start engine voltage should get to around 14.2 volts. if it stays at 12. or so you need a alternator. or a voltage regulator most likely. But it could be with the associated wiring to the alt. but not as likely.
