Hi All, I am trying to track down parts for a 2003 T190 tandem drive pump with the high flow option. I had a leak (I think) between the gear pump body and the main pump, so I took it to a hydraulic pump repair shop. we are having trouble locating the seal kit for the tandem drive pump. I think the Bobcat pump part number is 6686708. I was trying to cross it with a Sauer Danfoss part number to see if kits were more readily available( and cheaper) Does anyone know what the Sauer Danfoss part number would be? The only number I can find on the pump is a casting number 7095527. I also need the two swash plates ($525.00 each at Bobcat) unless anyone has had luck with SpeediSleeves for the shafts that the control arms connect to as the seals have worn a small groove on one side of the shafts. Thanks
