1845 case uniloader
rjphillips
I am looking for a used drive motor for a 1845 uniloader. When I push the right forward control I have little power. Left side is fine. I assume that is what is wrong.
antfarmer2
Swap the drive motors and see if the problem moves to the other side to be sure.......does it have drain case filters maybe pluged there
R
rjphillips
I don't know what you mean by does it have drain case filters maybe pluged there. It runs fine when you first start it up. When the fluid warms up then the left side looses power.
antfarmer2
Look for a metal cylinder on the hoses comming out of the motor.......loadersourceparts is a good place for parts if it is your motor I would replace or rebuild both the other is not far behind and clean the hydro system good
antfarmer2
Looks like you have a right and left drive pump on that looking at the prices hope it is not that and something simple or a drive motor they are $720 apiece
R
rjphillips
Yes I saw that 720.00 for a drive motor. I would like to find a good used one if I could. At about 1/2 that amount.
