T190 with intermitten code 41-09
KlineExc
We bought a T190 a couple of months ago. Haven't used it much and are getting a 41-09 code. I cracked the top of the battery when trying to get posts off. So it has a new battery. We thought that the old alternator was dirty/oily since we had a hose blow off the oil cooler right above the alternator. So we replaced alternator. However, we are still getting the 41-09 code. It doesn't come on, the battery light on panel, all the time. And will go off while using the machine. I have been looking through other posts but haven't found what I need yet. So I am hoping for some help. BTW this is our first Bobcat so more information maybe needed since it isn't the same as our New Holland.
Check the ALT and KITS 25 amp fuse, it is blown. All fuses are behind the cover between your legs. The fuse can blow because of a bad alternator, For what ever reason, the signal voltage that turns the alternator on is protected by this fuse. The fuse could also blow if the wiring to the cab door is damaged or if you have the 7 pin electrical connector by your aux couplers is smashed.
Here are all the Bobcat skid steer codes: LOADER XX‐XX Codes Code Description Code Description 01-16 Air Filter Not Connected 24-03 Rear Rod Solenoid Error Off 01-17 Air Filter Plugged 25-02 Rear Auxiliary Relief Solenoid Error On 02-16 Hydraulic Implement Filter Not Connected 25-03 Rear Auxiliary Relief Solenoid Error Off 02-17 Hydraulic Implement Filter Plugged 26-02 Front Base Solenoid Error On 03-09 Battery Voltage Low 26-03 Front Base Solenoid Error Off 03-10 Battery Voltage High 27-02 Front Rod Solenoid Error On 03-11 Battery Voltage Extremely High 27-03 Front Rod Solenoid Error Off 03-14 Battery Voltage Extremely Low 28-02 Diverter Solenoid Error On 03-22 Battery Voltage Out of Range Low 28-03 Diverter Solenoid Error Off 04-09 Engine Oil Pressure Low 29-02 High Flow Solenoid Error On 04-14 Engine Oil Pressure Extremely Low 29-03 High Flow Solenoid Error Off 04-15 Engine Oil Pressure In Shutdown 30-28 Controller Memory Failure 04-21 Engine Oil Pressure Out Of Range High 31-28 Interrupted Power 04-22 Engine Oil Pressure Out Of Range Low 33-23 Bobcat Controller Not Programmed 05-09 Hydraulic Charge Pressure Low 34-04 Deluxe Panel In Error 05-10 Hydraulic Charge Pressure High 35-02 Hydraulic Fan Error On 05-11 Hydraulic Charge Pressure Extremely High 35-03 Hydraulic Fan Error Off 05-14 Hydraulic Charge Pressure Extremely Low 36-48 Multiple ACDs Present 05-15 Hydraulic Charge Pressure In Shutdown 37-02 Two Speed Make-up Solenoid Error On 05-21 Hydraulic Charge Pressure Out Of Range High 37-03 Two Speed Make-up Error Off 05-22 Hydraulic Charge Pressure Out Of Range Low 37-07 Two Speed Secondary Solenoid Open Circuit 06-10 Engine Speed High 39-04 Left Joystick Switches In Error 06-11 Engine Speed Extremely High 39-12 Left CAN Joystick Thumb Paddle Switch Not In Neutral 06-13 Engine Speed No Signal 39-13 Left CAN Joystick Grip No Communication 06-15 Engine Speed In Shutdown 39-16 Left CAN Joystick Base No Communication 06-18 Engine Speed Out Of Range 39-28 Left CAN Joystick Internal Failure 07-10 Hydraulic Oil Temperature High 39-48 Left CAN Joystick Multiple 07-11 Hydraulic Oil Temperature Extremely High 40-04 Right Joystick Switches In Error 07-15 Hydraulic Oil Temperature In Shutdown 40-12 Right CAN Joystick Thumb Paddle Switch Not In Neutral 07-21 Hydraulic Oil Temperature Out Of Range High 40-13 Right CAN Joystick Grip No Communication 07-22 Hydraulic Oil Temperature Out Of Range Low 40-16 Right CAN Joystick Base No Communication 08-10 Engine Coolant Temperature High 40-28 Right CAN Joystick Internal Failure 08-11 Engine Coolant Temperature Extremely High 40-48 Right CAN Joystick Multiple 08-15 Engine Coolant Temperature In Shutdown 41-09 Alternator Low Output 08-21 Engine Coolant Temperature Out Of Range High 41-10 Alternator Voltage High 08-22 Engine Coolant Temp Out Of Range Low 41-11 Alternator Voltage Extremely High 09-09 Fuel Level Low 44-02 Horn Relay Error On 09-21 Fuel Level Out Of Range High 44-03 Horn Relay Error Off 09-22 Fuel Level Out Of Range Low 45-02 Right Blinker Relay Error On 10-16 Hydraulic Charge Filter Not Connected 45-03 Right Blinker Relay Error Off 10-17 Hydraulic Charge Filter Plugged 46-02 Left Blinker Relay Error On 11-05 Seat Bar Sensor Short To Battery 46-03 Left Blinker Relay Error Off 11-06 Seat Bar Sensor Short To Ground 47-21 8 Volt Sensor Supply Out Of Range High 12-21 Front Auxiliary Thumb Paddle Switch Out Of Range High 47-22 8 Volt Sensor Supply Out Of Range Low 12-22 Front Auxiliary Thumb Paddle Switch Out Of Range Low 48-02 Front Light Relay Error On 12-23 Front Auxiliary PWM Switch Not In Neutral 48-03 Front Light Relay Error Off 13-05 Fuel Shutoff Hold Coil Short To Battery 49-02 Rear Light Relay Error On 13-06 Fuel Shutoff Hold Solenoid Short To Ground 49-03 Rear Light Relay Error Off 13-07 Fuel Shutoff Hold Solenoid Open Circuit 60-21 Rear Auxiliary Control Out Of Range High 14-02 Fuel Shutoff Pull Coil Error On 60-22 Rear Auxiliary Control Out Of Range Low 14-03 Fuel Shutoff Pull Coil Error Off 60-23 Rear Auxiliary Control Not In Neutral 15-02 Traction Lock Pull Coil Error On 64-02 Switched Power Relay Error On 15-03 Traction Lock Pull Coil Error Off 64-03 Switched Power Relay Error Off 16-05 Traction Lock Hold Coil Short To Battery 74-72 Main Bobcat Controller In Boot Code 16-06 Traction Lock Hold Coil Short To Ground 76-73 Left Display Panel System Rx In Error 16-07 Traction Lock Hold Solenoid Open Circuit 77-48 Key Switch Multiple 17-05 Hydraulic Lock Solenoid Short To Battery 78-74 Door / Transport Lock Open / Active 17-06 Hydraulic Lock Solenoid Short To Ground 80-02 ACD/RACD Output "A" Error On 17-07 Hydraulic Lock Solenoid Open Circuit 80-03 ACD/RACD Output "A" Error Off 18-05 Spool Lock Coil Short To Battery 81-02 ACD/RACD Output "B" Error On 18-06 Spool Lock Coil Short To Ground 81-03 ACD/RACD Output "B" Error Off 18-07 Spool Lock Coil Open Circuit 82-02 ACD/RACD Output "C" Error On 19-02 Bucket Position Solenoid Error On 82-03 ACD/RACD Output "C" Error Off 19-03 Bucket Position Solenoid Error Off 83-02 ACD/RACD Output "D" Error On 20-02 Two Speed Solenoid Error On 83-03 ACD/RACD Output "D" Error Off 20-03 Two Speed Solenoid Error Off 84-02 ACD/RACD Output "E" Error On 21-02 Glow Plug Error On 84-03 ACD/RACD Output "E" Error Off 21-03 Glow Plug Error Off 85-02 ACD/RACD Output "F" Error On 22-02 Starter Error On 85-03 ACD/RACD Output "F" Error Off 22-03 Starter Error Off 86-02 ACD/RACD Output "G" Error On 23-02 Rear Base Solenoid Error On 86-03 ACD/RACD Output "G" Error Off 23-03 Rear Base Solenoid Error Off 87-02 ACD/RACD Output "H" Error On 24-02 Rear Rod Solenoid Error On 87-03 ACD/RACD Output "H" Error Off Bobcat Controller Bobcat Controller (Cont'd) Update June 2009 LOADER XX‐XX Codes Code Description 32-04 No Communication From ACS Controller Code Description 32-23 ACS Controller Not Calibrated 38-26 Left Rear Steering Sensor Out Of Range High 32-24 ACS Controller Calibration Performed 38-27 AWS / SJC Lift Actuator Out Of Range High 32-25 ACS Controller Calibration Failure 38-28 AWS / SJC Tilt Actuator Out Of Range High 32-31 ACS / AHC Tilt Actuator Fault 38-29 Left Joystick X-Axis Out Of Range Low 32-32 AHC Tilt Actuator Wiring Fault 38-30 Right Joystick X-axis Out Of Range Low 32-33 AHC Tilt Handle Wiring Fault 38-31 Left Joystick Y-Axis Out Of Range Low 32-34 ACS / AHC Tilt Actuator Not In Neutral 38-32 Right Joystick Y-Axis Out Of Range Low 32-35 ACS / AHC Tilt Handle / Pedal Not In Neutral, SJC Right Joystick X-axis Not In Neutral 38-33 Right Front Steering Sensor Out Of Range Low 32-36 ACS / AHC Lift Actuator Fault 38-34 Left Front Steering Sensor Out Of Range Low 32-37 AHC Lift Actuator Wiring Fault 38-35 Right Rear Steering Sensor Out Of Range Low 32-38 AHC Lift Handle Wiring Fault 38-36 Left Rear Steering Sensor Out Of Range Low 32-39 ACS / AHC Lift Actuator Not In Neutral 38-37 5 Volt Sensor Supply 1 Out Of Range Low 32-40 ACS / AHC Lift Handle / Pedal Not In Neutral, SJC Right Joystick Y-axis Not In Neutral 38-38 5 Volt Sensor Supply 2 Out Of Range Low 32-41 AHC Controller No Communication 38-39 AWS / SJC Lift Actuator Short To Ground 32-49 ACS Lift Actuator Short To Ground (Error Off) 38-40 AWS / SJC Tilt Actuator Short To Ground 32-50 ACS Tilt Actuator Short To Ground (Error Off) 38-41 Tilt Actuator Wrong Direction 32-51 ACS Lift Actuator Short To Battery (Error On) 38-42 Lift Actuator Wrong Direction 32-52 ACS Tilt Actuator Short To Battery (Error On) 38-43 Left Forward Drive Solenoid Error On 32-53 ACS Lift Handle / Pedal Short To Ground, SJC Right Joystick Y-axis Short To Ground 38-44 Left Reverse Drive Solenoid Error On 32-54 ACS Tilt Handle / Pedal Short To Ground, SJC Right Joystick X-axis Short To Ground 38-45 Right Forward Drive Solenoid Error On 32-55 ACS Lift Handle / Pedal Short To Battery, SJC Right Joystick Y-axis Short To Battery 38-46 Right Reverse Drive Solenoid Error On 32-56 ACS Tilt Handle Pedal Short To Battery, SJC Right Joystick X-axis Short To Battery 38-47 Right Front Steering Solenoid Error On 32-57 ACS Lift Actuator Reduced Performance 38-48 Left Front Steering Solenoid Error On 32-58 ACS Tilt Actuator Reduced Performance 38-49 Right Rear Steering Solenoid Error On 32-59 ACS Lift Actuator Wrong Direction 38-50 Left Rear Steering Solenoid Error On 32-60 ACS Tilt Actuator Wrong Direction 38-51 Pressure Control Steering Solenoid Error On 32-61 ACS Handle Lock Short To Ground 38-52 Backup Alarm Error On 32-62 ACS Handle Lock Short To Battery 38-53 Left Forward Drive Solenoid Error Off 32-63 ACS Pedal Lock Short To Ground 38-54 Left Reverse Drive Solenoid Error Off 32-64 ACS Pedal Lock Short To Battery 38-55 Right Forward Drive Solenoid Error Off 32-65 ACS Sensor Supply Voltage Out Of Range 38-56 Right Reverse Drive Solenoid Error Off 32-66 ACS Battery Voltage Out Of Range 38-57 Right Front Extend Steering Solenoid Error Off 32-67 ACS Operating Mode Switch Flipped While Operating 38-58 Right Front Retract Steering Solenoid Error Off 32-68 ACS Lift Handle Information Error 38-59 Left Front Extend Steering Solenoid Error Off 32-70 Right Joystick Y-axis Out Of Range Low 38-60 Left Front Retract Steering Solenoid Error Off 32-71 Right Joystick Y-axis Out Of Range High 38-61 Right Rear Extend Steering Solenoid Error Off 32-75 Interrupted Un-switched Power 38-62 Right Rear Retract Steering Solenoid Error Off 32-76 CAN Joystick Information Error 38-63 Left Rear Extend Steering Solenoid Error Off 32-97 ACS Controller Programmed 38-64 Left Rear Retract Steering Solenoid Error Off 40-05 Right CAN Joystick X-axis Not In Neutral 38-65 Pressure Control Steering Solenoid Error Off 40-07 Right CAN Joystick Y-axis Not In Neutral 38-66 Backup Alarm Short To Ground 38-67 No Communication From Bobcat Controller 38-68 Wheel Angle Sensors Not Calibrated 38-69 AWS / SJC Controller Not Calibrated 38-70 Interrupted Power 38-71 Battery Voltage Out Of Range Code Description 38-72 Drive Pump Not Calibrated 38-01 CAN Joystick Information Error 38-73 Operating Mode Switch Pressed While Operating 38-02 Remote Control Information Error 38-74 Right Wheel Speed Uncommanded Motion 38-03 Actuator Calibration Failure 38-75 Left Wheel Speed Uncommanded Motion 38-04 AWS/SJC Controller No Communication 38-85 5.0 Volt Sensor Supply 1 Out Of Range High 38-05 Left Analog Joystick X-Axis Not In Neutral 38-86 Sensor Supply 2 Out Of Range High 38-06 Right Analog Joystick X-Axis Not In Neutral 38-87 Right Front Steering Solenoid Error 38-07 Left Analog Joystick Y-Axis Not In Neutral 38-88 Left Front Steering Solenoid Error 38-08 Right Joystick Y-Axis Not In Neutral 38-89 Right Rear Steering Solenoid Error 38-09 Operating Mode Switch Short to Ground or Battery 38-90 Left Rear Steering Solenoid Error 38-10 Actuator Calibration Performed 38-93 Right Speed Sensor Unresponsive 38-11 AWS / SJC Lift Actuator Not In Neutral 38-94 Left Speed Sensor Unresponsive 38-12 AWS / SJC Tilt Actuator Not In Neutral 38-95 Left Speed Sensor Reverse Direction 38-13 AWS / SJC Lift Actuator Fault 38-96 Right Speed Sensor Reverse Direction 38-14 AWS / SJC Tilt Actuator Fault 38-97 AWS/SJC Controller Programmed 38-15 AWS / SJC Right Wheel Speed Fault 38-98 Controller In Drive Calibration Mode 38-16 AWS / SJC Left Wheel Speed Fault 38-99 AWS Controller In Wheel Position Calibration Mode 38-17 AWS / SJC Tilt Actuator Reduced Performance 39-05 Left CAN Joystick X-axis Not In Neutral 38-18 AWS / SJC Lift Actuator Reduced Performance 39-07 Left CAN Joystick Y-axis Not In Neutral 38-19 Left Joystick X-Axis Out Of Range High 40-05 Right CAN Joystick X-axis Not In Neutral 38-20 Right Joystick X-Axis Out Of Range High 40-07 Right CAN Joystick Y-axis Not In Neutral 38-21 Left Joystick Y-Axis Out Of Range High 38-22 Right Joystick Y-Axis Out Of Range High 38-23 Right Front Steering Sensor Out Of Range High 38-24 Left Front Steering Sensor Out Of Range High 38-25 Right Rear Steering Sensor Out Of Range High ACS Controller AWS-SJC Controller AWS-SJC Controller (Cont'd) Update June 2009 LOADER XX‐XX Codes Code Description Code Description 39-05 Left CAN Joystick X-axis Not In Neutral 75-82 Left Front Retract Steering Solenoid Error On 39-07 Left CAN Joystick Y-axis Not In Neutral 75-83 Right Rear Retract Steering Solenoid Error On 75-01 CAN Joystick Information Error 75-84 Left Rear Retract Steering Solenoid Error On 75-04 No Communication From Drive Controller 75-85 5.0 Volt Sensor Supply 1 Out Of Range High 75-05 Left Joystick X-axis Not In Neutral Left (ISO Mode Only) 75-86 Sensor Supply 2 Out Of Range High 75-07 Left Joystick Y-axis Not In Neutral 75-87 Software Update Required 75-08 Right Joystick Y-axis Not In Neutral (H-Pattern Only) 75-88 Switched Power Error On 75-09 Operating Mode Switch Short To Ground Or Battery 75-91 Left Swash Plate Sensor - Reversed 75-13 Right Front Wheel Unresponsive 75-92 Right Swash Plate Sensor - Reversed 75-14 Left Front Wheel Unresponsive 75-93 Unresponsive Right Speed Sensor 75-15 Right Rear Wheel Unresponsive 75-94 Unresponsive Left Speed Sensor 75-16 Left Rear Wheel Unresponsive 75-95 Left Speed Sensor Reverse Direction 75-17 Left Swash Plate Not In Neutral 75-96 Right Speed Sensor Reverse Direction 75-18 Right Swash Plate Not In Neutral 75-97 Drive / Drive Plus Controller Programmed 75-19 Left Joystick X-axis Out Of Range High 75-98 Controller In Calibration Mode 75-21 Left Joystick Y-axis Out Of Range High 75-99 Drive Plus Controller In Wheel Position Calibration Mode 75-23 Right Front Steering Sensor Out Of Range High 75-24 Left Front Steering Sensor Out Of Range High 75-25 Right Rear Steering Sensor Out Of Range High 75-26 Left Rear Steering Sensor Out Of Range High 75-27 Left Swash Plate Out Of Position 75-28 Right Swash Plate Out Of Position 75-29 Left Joystick X-axis Out Of Range Low 75-31 Left Joystick Y-axis Out Of Range Low 75-33 Right Front Steering Sensor Out Of Range Low 75-34 Left Front Steering Sensor Out Of Range Low 75-35 Right Rear Steering Sensor Out Of Range Low 75-36 Left Rear Steering Sensor Out Of Range Low 75-37 5.0 Volt Sensor Supply 1 Out Of Range Low 75-38 5 Volt Sensor Supply 2 Out Of Range Low 75-39 Left Swash Plate Sensor Out Of Range High 75-40 Left Swash Plate Sensor Out Of Range Low 75-41 Right Swash Plate Sensor Out Of Range High 75-42 Right Swash Plate Sensor Out Of Range Low 75-43 Left Forward Drive Solenoid Error On 75-44 Left Reverse Drive Solenoid Error On 75-45 Right Forward Drive Solenoid Error On 75-46 Right Reverse Drive Solenoid Error On 75-47 Right Front Extend Steering Solenoid Error On 75-48 Left Front Extend Steering Solenoid Error On 75-49 Right Rear Extend Steering Solenoid Error On 75-50 Left Rear Extend Steering Solenoid Error On 75-51 Pressure Control Steering Solenoid Error On 75-52 Backup Alarm Error On 75-53 Left Forward Drive Solenoid Error Off 75-54 Left Reverse Drive Solenoid Error Off 75-55 Right Forward Drive Solenoid Error Off 75-56 Right Reverse Drive Solenoid Error Off 75-57 Right Front Extend Steering Solenoid Error Off 75-58 Right Front Retract Steering Solenoid Error Off 75-59 Left Front Extend Steering Solenoid Error Off 75-60 Left Front Retract Steering Solenoid Error Off 75-61 Right Rear Extend Steering Solenoid Error Off 75-62 Right Rear Retract Steering Solenoid Error Off 75-63 Left Rear Extend Steering Solenoid Error Off 75-64 Left Rear Retract Steering Solenoid Error Off 75-65 Pressure Control Steering Solenoid Error Off 75-66 Backup Alarm Error Off 75-67 No Communication From Bobcat Controller 75-68 Angle Sensors Not Calibrated 75-69 Battery Voltage Out Of Range High 75-70 Interrupted Power 75-71 Battery Voltage Out Of Range Low 75-72 Drive Pump – Not Calibrated 75-73 Operating Mode Switch Flipped While Operating 75-74 Right Wheel Speed Uncommanded Motion 75-75 Left Wheel Speed Uncommanded Motion 75-76 No Communication From ACS Controller 75-77 Left Speed Sensor Out Of Range High 75-78 Right Speed Sensor Out Of Range High 75-79 Left Speed Sensor Out Of Range Low 75-80 Right Speed Sensor Out Of Range Low 75-81 Right Front Retract Steering Solenoid Error On SSL Drive / Drive Plus Controller SSL Drive / Drive Plus Controller Update June 2009 LOADER ALPHA‐NUMERIC CODES Code Description Code Description M0116 Air Filter Not Connected M2128 Glow Plug Output Controller Failure M0117 Air Filter Plugged M2202 Starter Output Error On M0216 Hydraulic Implement Filter Not Connected M2203 Starter Output Error Off M0217 Hydraulic Implement Filter Plugged M2207 Starter Output Open Circuit M0309 Battery Voltage Low M2228 Starter Output Controller Failure M0310 Battery Voltage High M2302 Starter Relay Error On M0311 Battery Voltage Extremely High M2303 Starter Relay Error Off M0314 Battery Voltage Extremely Low M2307 Starter Relay Open Circuit M0322 Battery Voltage Out Of Range Low M2402 Fuel Pull Relay Error On M0409 Engine Oil Pressure Low M2403 Fuel Pull Relay Error Off M0414 Engine Oil Pressure Extremely Low M2407 Fuel Pull Output Open Circuit M0415 Engine Oil Pressure In Shutdown M2502 Traction Lock Relay Error On M0421 Engine Oil Pressure Out Of Range High M2503 Traction Lock Pull Relay Error Off M0422 Engine Oil Pressure Out Of Range Low M2507 Traction Lock Output Open Circuit M0509 Hydraulic Charge Pressure Low M2602 Glow Plug Relay Error On M0510 Hydraulic Charge Pressure High M2603 Glow Plug Relay Error Off M0511 Hydraulic Charge Pressure Extremely High M2607 Glow Plug Output Open Circuit M0514 Hydraulic Charge Pressure Extremely Low M2805 Auxiliary Interlock Output Short To Battery M0515 Hydraulic Charge Pressure In Shutdown M2806 Auxiliary Interlock Output Short To Ground M0521 Hydraulic Charge Pressure Out Of Range High M2807 Auxiliary Interlock Output Open Circuit M0522 Hydraulic Charge Pressure Out Of Range Low M3028 Controller Memory Failure M0610 Engine Speed High M3128 Interrupted Power Failure M0611 Engine Speed Extremely High M3204 ACS In Error M0613 Engine Speed No Signal M3304 Deluxe Panel No Communication M0615 Engine Speed In Shutdown M3323 Gateway Controller Not Programmed M0618 Engine Speed Out Of Range M3404 Deluxe Panel No Communication M0710 Hydraulic Oil Temperature High M3505 Hydraulic Fan Solenoid Error On M0711 Hydraulic Oil Temperature Extremely High M3506 Hydraulic Fan Solenoid Error Off M0715 Hydraulic Oil Temperature In Shutdown M3507 Hydraulic Fan Solenoid Open Circuit M0721 Hydraulic Oil Temperature Out Of Range High M3532 Hydraulic Fan Solenoid Over Current M0722 Hydraulic Oil Temperature Out Of Range Low M3648 Multiple ACDs Present (Attachment Control Device) M0810 Engine Coolant Temperature High M3705 Two Speed Secondary Error On M0811 Engine Coolant Temperature Extremely High M3706 Two Speed Secondary Error Off M0815 Engine Coolant Temperature In Shutdown M3707 Two Speed Secondary Solenoid Open Circuit M0821 Engine Coolant Temperature Out Of Range High M3732 Two Speed Secondary Over Current M0822 Engine Coolant Temperature Out Of Range Low M4109 Alternator Low Output M0909 Fuel Level Low M4110 Alternator Voltage High M0921 Fuel Level Out Of Range High M4404 Auxiliary Controller No Communication M0922 Fuel Level Out Of Range Low M4621 5 Volt Sensor Supply Out Of Range High M1016 Hydraulic Charge Filter Not Connected M4622 5 Volt Sensor Supply Out Of Range Low M1017 Hydraulic Charge Filter Plugged M4721 8 Volt Sensor Supply Out Of Range High M1121 Seatbar Sensor Out Of Range High M4722 8 Volt Sensor Supply Out Of Range Low M1122 Seatbar Sensor Out Of Range Low M4802 Front Light Relay Error On M1305 Fuel Shutoff Hold Coil Short To Battery M4803 Front Light Relay Error Off M1306 Fuel Shutoff Hold Coil Short To Ground M4807 Front Light Output Open Circuit M1307 Fuel Shutoff Hold Coil Open Circuit M4902 Rear Light Relay Error On M1402 Fuel Pull Output Error On M4903 Rear Light Relay Error Off M1403 Fuel Pull Output Error Off M4907 Rear Light Output Open Circuit M1407 Fuel Pull Output Open Circuit M5002 Front Light Output Error On M1428 Fuel Pull Output Controller Failure M5003 Front Light Output Error Off M1502 Traction Lock Pull Output Error On M5007 Front Light Output Open Circuit M1503 Traction Lock Pull Output Error Off M5028 Front Light Output Controller Failure M1507 Traction Lock Pull Output Open Circuit M5102 Rear Light Output Error On M1528 Traction Lock Pull Output Controller Failure M5103 Rear Light Output Error Off M1605 Traction Lock Hold Solenoid Short To Battery M5107 Rear Light Output Open Circuit M1606 Traction Lock Hold Solenoid Short To Ground M5128 Front Light Output Controller Failure M1607 Traction Lock Hold Solenoid Open Circuit M5202 PTOL (Press To Operate Loader)Switch Error On M1705 Hydraulic Lock Valve Solenoid Short To Battery M5221 PTOL Switch Out Of Range High M1706 Hydraulic Lock Valve Solenoid Short To Ground M5222 PTOL Switch Out Of Range Low M1707 Hydraulic Lock Valve Solenoid Open Circuit M5305 PTOL Led Short To Battery M1732 Hydraulic Lock Valve Solenoid Over Current M5306 PTOL Led Short To Ground M1805 Lift Spool Lock Short To Battery M5405 Tilt Spool Lock Short To Battery M1806 Lift Spool Lock Short To Ground M5406 Tilt Spool Lock Short To Ground M1807 Lift Spool Lock Open Circuit M5407 Tilt Spool Lock Open Circuit M1832 Lift Spool Lock Solenoid Over Current M5432 Tilt Spool Lock Over Current M2005 Two Speed Solenoid Short To Battery M6402 Switched Power Relay Error On M2006 Two Speed Solenoid Short To Ground M6403 Switched Power Relay Error Off M2007 Two Speed Solenoid Open Circuit M6407 Switched Power Output Open Circuit M2032 Two Speed Solenoid Over Current M7002 Switched Power Output Error On M2102 Glow Plug Output Error On M7003 Switched Power Output Error Off M2103 Glow Plug Output Error Off M7007 Switched Power Output Open Circuit M2107 Glow Plug Output Open Circuit M7028 Switched Power Output Controller Failure Gateway Controller Gateway Controller (Cont'd) Updated June 2009 LOADER ALPHA‐NUMERIC CODES Code Description Code Description M7304 Remote Control Receiver No Communication A8002 ACD/RACD Output "A" Error On M7423 Gateway Controller Not Programmed A8003 ACD/RACD Output "A" Error Off M7472 Gateway Controller In Boot Code A8102 ACD/RACD Output "B" Error On M7504 Drive Controller No Communication A8103 ACD/RACD Output "B" Error Off M7604 Left Display Panel No Communication A8202 ACD/RACD Output "C" Error On M7748 Key Switch Multiple A8203 ACD/RACD Output "C" Error Off M7974 Door Open A8302 ACD/RACD Output "D" Error On A8303 ACD/RACD Output "D" Error Off A8402 ACD/RACD Output "E" Error On A8403 ACD/RACD Output "E" Error Off A8502 ACD/RACD Output "F" Error On A8503 ACD/RACD Output "F" Error Off Code Description A8602 ACD/RACD Output "G" Error On H1221 Front Auxiliary Thumb Paddle Switch Out Of Range High A8603 ACD/RACD Output "G" Error Off H1222 Front Auxiliary Thumb Paddle Switch Out Of Range Low A8702 ACD/RACD Output "H" Error On H1224 Front Auxiliary Thumb Paddle Switch Not In Neutral A8703 ACD/RACD Output "H" Error Off H1324 Rear Auxiliary Thumb Paddle Switch Not In Neutral H2305 Rear Base Solenoid Shorted to Battery H2306 Rear Base Solenoid Short To Ground H2307 Rear Base Solenoid Open Circuit H2332 Rear Base Solenoid Over Current H2405 Rear Rod Solenoid Short To Battery Code Description H2406 Rear Rod Solenoid Short To Ground W3223 ACS Controller Not Calibrated H2407 Rear Rod Solenoid Open Circuit W3224 ACS Controller Calibration Successful H2432 Rear Rod Solenoid Over Current W3225 ACS Controller Calibration Failure H2605 Front Base Solenoid Short To Battery W3231 ACS Tilt Actuator Fault H2606 Front Base Solenoid Short To Ground W3234 ACS Tilt Actuator Not In Neutral H2607 Front Base Solenoid Open Circuit W3235 ACS Tilt Handle/Pedal Not In Neutral H2632 Front Base Solenoid Over Current W3236 ACS Lift Actuator Fault H2705 Front Rod Solenoid Short To Battery W3239 ACS Lift Actuator Not In Neutral (ACS Only) H2706 Front Rod Solenoid Short To Ground W3240 ACS Lift Handle/Pedal Not In Neutral H2707 Front Rod Solenoid Open Circuit W3249 ACS Lift Actuator Short To Ground (Error Off) (ACS Only) H2732 Front Rod Solenoid Over Current W3250 ACS Tilt Actuator Short To Ground (Error Off) H2805 Diverter Solenoid Short To Battery W3251 ACS Lift Actuator Short To Battery (Error On) (ACS Only) H2806 Diverter Solenoid Short To Ground W3252 ACS Tilt Actuator Short To Battery (Error On) H2807 Diverter Solenoid Open Circuit W3253 ACS Lift Handle/Pedal Short To Ground H2905 High Flow Solenoid Short To Battery W3254 ACS Tilt Handle/Pedal Short To Ground H2906 High Flow Solenoid Short To Ground W3255 ACS Lift Handle/Pedal Short To Battery H2907 High Flow Solenoid Open Circuit W3256 ACS Tilt Handle/Pedal Short To Battery H2932 High Flow Solenoid Over Current W3257 ACS Lift Actuator Reduced Performance H3028 Auxiliary Controller Memory Failure W3258 ACS Tilt Actuator Reduced Performance H3128 Interrupted Power Failure W3259 ACS Lift Actuator Wrong Direction (ACS Only) H3648 Multiple ACDs Present (Attachment Control Device) W3260 ACS Tilt Actuator Wrong Direction H3913 Left CAN Joystick Grip No Communication W3261 ACS Handle Lock Short To Ground H3916 Left CAN Joystick Base No Communication W3262 ACS Handle Lock Short To Battery H3928 Left CAN Joystick Internal Failure W3263 ACS Pedal Lock Short To Ground H3948 Left CAN Joystick Multiple W3264 ACS Pedal Lock Short To Battery H4013 Right CAN Joystick Grip No Communication W3265 ACS Sensor Supply Voltage Out Of Range (ACS Only) H4016 Right CAN Joystick Base No Communication W3266 ACS Battery Voltage Out Of Range (ACS Only) H4028 Right CAN Joystick Internal Failure W3267 ACS Operating Mode Switch Flipped While Operating H4048 Right CAN Joystick Multiple W3275 Interrupted Un-switched Power H4302 Horn Relay Error On W3276 CAN Joystick Information Error H4303 Horn Relay Error Off W3297 ACS Controller Programmed H4423 Auxiliary Controller Not Programmed W3905 Left CAN Joystick X-axis Not In Neutral H4502 Right Blinker Error On W4005 Right CAN Joystick X-axis Not In Neutral H4503 Right Blinker Error Off W4007 Right CAN Joystick Y-axis Not In Neutral H4602 Left Blinker Error On H4603 Left Blinker Error Off H4721 8 Volt Sensor Supply Out Of Range High H4722 8 Volt Sensor Supply Out Of Range Low H7404 Gateway Controller No Communication H7604 Left Display Panel No Communication Code Description L0102 Lights Button Error On L0202 High Flow Button Error On L0302 Auxiliary Button Error On L0402 Information Button Error On L7404 Gateway Controller No Communication L7672 Left Hand Panel Programming Error Gateway Controller (Cont'd) Auxiliary Controller ACD Controller ACS Controller Left Hand Panel Controller Updated June 2009 LOADER ALPHA‐NUMERIC CODES Code Description Code Description D3905 Left CAN Joystick X Axis Not in Neutral D7591 Left Swash Plate Sensor - Reversed D3907 Left CAN Joystick Y-axis Not In Neutral D7592 Right Swash Plate Sensor - Reversed D4007 Right CAN Joystick Y-axis Not In Neutral D7593 Unresponsive Right Speed Sensor D7501 CAN Joystick Information Error D7594 Unresponsive Left Speed Sensor D7509 Operating Mode Switch Short To Ground Or Battery D7595 Left Speed Sensor Reverse Direction D7513 Right Front Wheel Unresponsive D7596 Right Speed Sensor Reverse Direction D7514 Left Front Wheel Unresponsive D7597 Drive / Drive Plus Controller Programmed D7515 Right Rear Wheel Unresponsive D7598 Drive / Drive Plus Controller In Calibration Mode D7516 Left Rear Wheel Unresponsive D7599 Drive Plus Controller In Wheel Position Calibration Mode D7517 Left Swash Plate Not In Neutral D7518 Right Swash Plate Not In Neutral D7523 Right Front Steering Sensor Out Of Range High D7524 Left Front Steering Sensor Out Of Range High D7525 Right Rear Steering Sensor Out Of Range High D7526 Left Rear Steering Sensor Out Of Range High D7527 Left Swash Plate Out Of Position D7528 Right Swash Plate Out Of Position D7533 Right Front Steering Sensor Out Of Range Low D7534 Left Front Steering Sensor Out Of Range Low D7535 Right Rear Steering Sensor Out Of Range Low D7536 Left Rear Steering Sensor Out Of Range Low D7537 5.0 Volt Sensor Supply 1 Out Of Range Low D7538 5 Volt Sensor Supply 2 Out Of Range Low D7539 Left Swash Plate Sensor Out Of Range High D7540 Left Swash Plate Sensor Out Of Range Low D7541 Right Swash Plate Sensor Out Of Range High D7542 Right Swash Plate Sensor Out Of Range Low D7543 Left Forward Drive Solenoid Error On D7544 Left Reverse Drive Solenoid Error On D7545 Right Forward Drive Solenoid Error On D7546 Right Reverse Drive Solenoid Error On D7547 Right Front Extend Steering Solenoid Error On D7548 Left Front Extend Steering Solenoid Error On D7549 Right Rear Extend Steering Solenoid Error On D7550 Left Rear Extend Steering Solenoid Error On D7551 Pressure Control Steering Solenoid Error On D7552 Backup Alarm Error On D7553 Left Forward Drive Solenoid Error Off D7554 Left Reverse Drive Solenoid Error Off D7555 Right Forward Drive Solenoid Error Off D7556 Right Reverse Drive Solenoid Error Off D7557 Right Front Extend Steering Solenoid Error Off D7558 Right Front Retract Steering Solenoid Error Off D7559 Left Front Extend Steering Solenoid Error Off D7560 Left Front Retract Steering Solenoid Error Off D7561 Right Rear Extend Steering Solenoid Error Off D7562 Right Rear Retract Steering Solenoid Error Off D7563 Left Rear Extend Steering Solenoid Error Off D7564 Left Rear Retract Steering Solenoid Error Off D7565 Pressure Control Steering Solenoid Error Off D7566 Backup Alarm Error Off D7567 No Communication From Gateway Controller D7568 Angle Sensors Not Calibrated D7569 Battery Voltage Out Of Range High D7570 Interrupted Power D7571 Battery Voltage Out Of Range Low D7572 Drive Pump – Not Calibrated D7573 Operating Mode Switch Flipped While Operating D7574 Right Wheel Speed Uncommanded Motion D7575 Left Wheel Speed Uncommanded Motion D7577 Left Speed Sensor Out Of Range High D7578 Right Speed Sensor Out Of Range High D7579 Left Speed Sensor Out Of Range Low D7580 Right Speed Sensor Out Of Range Low D7581 Right Front Retract Steering Solenoid Error On D7582 Left Front Retract Steering Solenoid Error On D7583 Right Rear Retract Steering Solenoid Error On D7584 Left Rear Retract Steering Solenoid Error On D7585 5.0 Volt Sensor Supply 1 Out Of Range High D7586 Sensor Supply 2 Out Of Range High D7587 Software Update Required D7588 Switched Power Stuck On SSL Drive / Drive Plus Controller SSL Drive / Drive Plus Controller (Cont'd) Updated June 2009 EXCAVATOR XX‐XX CODES Code Description Code Description 02-16 Hydraulic/Hydrostatic Filter Not Connected 20-03 Two Speed Error Off 02-17 Hydraulic/Hydrostatic Filter Plugged 21-02 Glow Plug Error On 03-09 Battery Voltage Low 21-03 Glow Plug Error Off 03-10 Battery Voltage High 22-02 Starter Error On 03-11 Battery Voltage Extremely High 22-03 Starter Error Off 03-14 Battery Voltage Extremely Low 26-02 Front Base Solenoid Error On 03-15 Battery Voltage In Shutdown 26-03 Front Base Solenoid Error Off 03-22 Battery Voltage Out Of Range Low 26-05 Front Base PWM Short to Battery 04-14 Engine Oil Pressure Extremely Low 26-06 Front Base PWM Short to Ground 04-15 Engine Oil Pressure Shutdown Level 26-07 Front Base PWM Open Circuit 05-09 Travel Pilot Pressure Low 27-02 Front Rod Solenoid Error On 05-14 Travel Pilot Pressure Extremely Low 27-03 Front Rod Solenoid Error Off 05-15 Travel Pilot Pressure In Shutdown 27-05 Front Rod PWM Short to Battery 05-21 Travel Pilot Pressure Out Of Range High 27-06 Front Rod PWM Short to Ground 05-22 Travel Pilot Pressure Out Of Range Low 27-07 Front Rod PWM Open Circuit 06-10 Engine Speed High 28-02 Diverter Solenoid Error On 06-11 Engine Speed Extremely High 28-03 Diverter Solenoid Error Off 06-13 Engine Speed No Signal 31-28 Interrupted Power Failure 06-15 Engine Speed In Shutdown 33-23 Main Controller Not Programmed 06-18 Engine Speed Out Of Range High 35-05 Hydraulic Fan Short To Battery 07-10 Hydraulic Oil Temperature High 35-06 Hydraulic Fan Short To Ground 07-11 Hydraulic Oil Temperature Extremely High 62-04 Load Moment Monitoring In Error 07-15 Hydraulic Oil Temperature In Shutdown 63-05 Console Switch Short To Battery 07-21 Hydraulic Oil Temperature Out Of Range High 63-06 Console Switch Short To Ground 07-22 Hydraulic Oil Temperature Out Of Range Low 64-05 Switched Power Relay Short To Battery 08-10 Engine Coolant Temperature High 64-06 Switched Power Relay Short To Ground 08-11 Engine Coolant Temperature Extremely High 64-07 Switched Power Relay Open Circuit 08-15 Engine Coolant Temperature In Shutdown 65-05 Workgroup Lockout Solenoid Short To Battery 08-21 Engine Coolant Temperature Out Of Range High 65-06 Workgroup Lockout Solenoid Short To Ground 08-22 Engine Coolant Temperature Out Of Range Low 65-07 Workgroup Lockout Solenoid Open Circuit 09-21 Fuel Level Out Of Range High 66-05 Travel Pilot Pressure Short To Battery 09-22 Fuel Level Out Of Range Low 66-06 Travel Pilot Pressure Short To Ground 12-21 Auxiliary PWM Switch Out Of Range High 66-07 Travel Pilot Pressure Open Circuit 12-22 Auxiliary PWM Switch Out Of Range Low 12-23 Auxiliary PWM Switch Not In Neutral 13-05 Fuel Shutoff Hold Solenoid Short To Battery 13-06 Fuel Shutoff Hold Solenoid Short To Ground 13-07 Fuel Shutoff Hold Solenoid Open Circuit 14-02 Fuel Shutoff Pull Solenoid Error On 14-03 Fuel Shutoff Pull Solenoid Error Off 20-02 Two Speed Error On 20-03 Two Speed Error Off 21-02 Glow Plug Error On 21-03 Glow Plug Error Off 22-02 Starter Error On 22-03 Starter Error Off 26-02 Front Base Solenoid Error On 26-03 Front Base Solenoid Error Off 26-05 Front Base PWM Short to Battery 26-06 Front Base PWM Short to Ground 26-07 Front Base PWM Open Circuit 27-02 Front Rod Solenoid Error On 27-03 Front Rod Solenoid Error Off 27-05 Front Rod PWM Short to Battery 27-06 Front Rod PWM Short to Ground Excavator Display Controller Excavator Display Controller Updated June 2009 EXCAVATOR ALPHA‐NUMERIC CODES Code Description Code Description C0216 Hydraulic/Hydrostatic Filter Not Connected C2803 Hydraulic Exchange Error Off C0217 Hydraulic/Hydrostatic Filter Plugged C3028 Controller Memory Failure C0309 Battery Voltage Low C3128 Interrupted Power Failure C0310 Battery Voltage High C3323 Main Controller Not Programmed C0311 Battery Voltage Extremely High C3397 Main Controller Programmed C0314 Battery Voltage Extremely Low C4021 Angle Blade Control Out Of Range High C0315 Battery Voltage In Shutdown C4022 Angle Blade Control Out Of Range Low C0322 Battery Voltage Out Of Range Low C4023 Angle Blade Control Not In Neutral C0414 Engine Oil Pressure Extremely Low C4105 Angle Blade Base Solenoid Short to Battery C0415 Engine Oil Pressure In Shutdown C4106 Angle Blade Base Solenoid Short to Ground C0610 Engine Speed High C4107 Angle Blade Base Solenoid Open Circuit C0611 Engine Speed Extremely High C4205 Angle Blade Rod Solenoid Short to Battery C0613 Engine Speed No Signal C4206 Angle Blade Rod Solenoid Short to Ground C0615 Engine Speed In Shutdown C4207 Angle Blade Rod Solenoid Open Circuit C0618 Engine Speed Out Of Range High C4321 Load Sense Pressure Out Of Range High C0710 Hydraulic Oil Temperature High C4322 Load Sense Pressure Out Of Range Low C0711 Hydraulic Oil Temperature Extremely High C4516 Throttle Controller No Communication C0715 Hydraulic Oil Temperature In Shutdown C6021 Offset Control Out Of Range High C0721 Hydraulic Oil Temperature Out Of Range High C6022 Offset Control Out Of Range Low C0722 Hydraulic Oil Temperature Out Of Range Low C6023 Offset Control Not In Neutral C0810 Engine Coolant Temperature High C6204 Load Moment Monitoring In Error C0811 Engine Coolant Temperature Extremely High C6305 Console Switch Short To Battery C0815 Engine Coolant Temperature In Shutdown C6306 Console Switch Short To Ground C0821 Engine Coolant Temperature Out Of Range High C6405 Switched Power Relay Short To Battery C0822 Engine Coolant Temperature Out Of Range Low C6406 Switched Power Relay Short To Ground C0921 Fuel Level Out Of Range High C6407 Switched Power Relay Open Circuit C0922 Fuel Level Out Of Range Low C6505 Workgroup Lockout Solenoid Short To Battery C1221 Auxiliary PWM Switch Out Of Range High C6506 Workgroup Lockout Solenoid Short To Ground C1222 Auxiliary PWM Switch Out Of Range Low C6507 Workgroup Lockout Solenoid Open Circuit C1223 Auxiliary PWM Switch Not In Neutral C1305 Fuel Shutoff Hold Solenoid Short To Battery C1306 Fuel Shutoff Hold Solenoid Short To Ground C1307 Fuel Shutoff Hold Solenoid Open Circuit Code Description C1402 Fuel Shutoff Pull Solenoid Error On E0105 Throttle Actuator Short To Battery C1403 Fuel Shutoff Pull Solenoid Error Off E0106 Throttle Actuator Short To Ground C2005 Two Speed Error On E0107 Throttle Actuator Open Circuit C2006 Two Speed Error Off E0123 Throttle Controller Not Calibrated C2102 Glow Plug Error On E0321 5 Volt Sensor Supply Out Of Range High C2103 Glow Plug Error Off E0322 5 Volt Sensor Supply Out Of Range Low C2202 Starter Error On E0421 Engine Speed Control Dial Out Of Range High C2203 Starter Error Off E0422 Engine Speed Control Dial Out Of Range Low C2305 Offset Base Solenoid Short To Battery E0521 Throttle Actuator Feedback Out Of Range High C2306 Offset Base Solenoid Short to Ground E0522 Throttle Actuator Feedback Out Of Range Low C2307 Offset Base Solenoid Open Circuit C2405 Offset Rod Solenoid Short To Battery C2406 Offset Rod Solenoid Short to Ground C2407 Offset Rod Solenoid Open Circuit C2505 Offset Return Short To Battery C2506 Offset Return Short To Ground C2507 Offset Return Open Circuit C2605 Auxiliary Base Solenoid Short to Battery C2606 Auxiliary Base Solenoid Short to Ground C2607 Auxiliary Base Solenoid Open Circuit C2705 Auxiliary Rod Solenoid Short to Battery C2706 Auxiliary Rod Solenoid Short to Ground C2707 Auxiliary Rod Solenoid Open Circuit C2802 Hydraulic Exchange Error On Excavator Display Controller Excavator Display Controller (Cont'd) Engine Controller Updated June 2009 E60/E80 E‐ECU CONTROLLER CODES Code Description P0117 Engine Coolant Temperature Sensor Out Of Range Low P0118 Engine Coolant Temperature Sensor Out Of Range High P0119 Engine Coolant Temperature Sensor Intermittent Connection P0122 Accelerator Sensor Out Of Range Low P0123 Accelerator Sensor Out Of Range High P0124 Accelerator Sensor Intermittent Connection P0217 Engine Coolant Temperature High P0340 Engine Speed Sensor No Signal P0562 Battery Voltage Low P0563 Battery Voltage High P0605 E-ECU Internal FlashROM Checksum Error A (Main Software) P0634 E-ECU Temperature Sensor High P0642 5 Volt Sensor Supply Out Of Range Low P0643 5 Volt Sensor Supply Out Of Range High P0668 E-ECU Temperature Sensor Out Of Range Low P0669 E-ECU Temperature Sensor Out Of Range High P1202 Rack Position Sensor Out Of Range Low P1203 Rack Position Sensor Out of Range High P1211 Rack Actuator Solenoid Stuck P1212 Rack Actuator Solenoid Undercurrent P1213 Rack Actuator Solenoid Overcurrent P1222 Rack Actuator Relay Error On P1223 Rack Actuator Relay Error Off P1224 Rack Actuator Relay Intermittent Connection P1232 Preheat relay Error On P1233 Preheat relay Error Off P1234 Preheat Relay Intermittent Connection P1242 CSD Solenoid Valve Error On P1243 CSD Solenoid Valve Error Off P1244 CSD Solenoid Valve Intermittent Connection P1402 EGR Valve Phase A Error On P1403 EGR Valve Phase A Error Off P1412 EGR Valve Phase B Error On P1413 EGR Valve Phase B Error Off P1422 EGR Valve Phase C Error On P1423 EGR Valve Phase C Error Off P1432 EGR Valve Phase D Error On P1433 EGR Valve Phase D Error Off P1605 E-ECU Internal FlashROM Checksum Error B (Main Software) P1606 E-ECU Internal FlashROM Checksum Error C (Main Software) P1644 5 Volt Sensor Supply Intermittent Connection P1664 E-ECU Temperature Sensor Intermittent Connection E60/E80 E-ECU Controller TOOLCAT XX‐XX CODES Code Description Code Description 02-16 Hydraulic Charge Filter Not Connected 50-01 Drive Pedal Out Of Range High 02-17 Hydraulic Charge Filter Plugged 50-02 Drive Pedal Out Of Range Low 03-09 Battery Voltage Low 50-03 Travel Pedal Not Calibrated 03-10 Battery Voltage High 50-04 Brake Pedal Out Of Range High 03-11 Battery Voltage Extremely High 50-05 Brake Pedal Out Of Range Low 03-14 Battery Voltage Extremely Low 50-06 Brake Pedal Not Calibrated 03-15 Battery Voltage In Shutdown 50-07 Travel Direction Control Lever No Signal 03-22 Battery Voltage Out Of Range Low 50-08 Travel Direction Control Lever Multiple Inputs 04-14 Engine Oil Pressure Extremely Low 50-09 Front Wheel Speed Sensor Out Of Range High 04-15 Engine Oil Pressure Shutdown Level 50-10 Front Wheel Speed Sensor Out Of Range Low 06-10 Engine Speed High 50-11 Rear Wheel Speed Sensor Out Of Range High 06-11 Engine Speed Extremely High 50-12 Rear Wheel Speed Sensor Out Of Range Low 06-13 Engine Speed No Signal 50-13 Front Wheel Speed Sensor No Signal 06-15 Engine Speed In Shutdown 50-14 Rear Wheel Speed Sensor No Signal 06-18 Engine Speed Out Of Range High 50-15 Dual Wheel Speed Sensor Fault 07-10 Hydraulic Oil Temperature High 50-19 Swash Plate Sensor Out Of Range High 07-11 Hydraulic Oil Temperature Extremely High 50-20 Swash Plate Sensor Out Of Range Low 07-15 Hydraulic Oil Temperature In Shutdown 50-24 Battery Voltage Over Voltage 07-21 Hydraulic Oil Temperature Out Of Range High 50-25 Battery Voltage Under Voltage 07-22 Hydraulic Oil Temperature Out Of Range Low 50-26 Interrupted Power 08-10 Engine Coolant Temperature High 50-27 5.0 Volt Sensor Supply 1 Out Of Range High 08-11 Engine Coolant Temperature Extremely High 50-28 5.0 Volt Sensor Supply 1 Out Of Range Low 08-15 Engine Coolant Temperature In Shutdown 50-29 5.0 Volt Sensor Supply 2 Out Of Range High 08-21 Engine Coolant Temperature Out Of Range High 50-30 5.0 Volt Sensor Supply 2 Out Of Range Low 08-22 Engine Coolant Temperature Out Of Range Low 50-31 Front Drive PWM Solenoid Error On 09-09 Fuel Level Low 50-32 Forward Drive Coil Short To Battery 09-21 Fuel Level Out Of Range High 50-33 Front Drive PWM Solenoid No Signal 09-22 Fuel Level Out Of Range Low 50-34 Front Drive PWM Solenoid Not Calibrated 12-21 Auxiliary PWM Switch Out Of Range High 50-35 Front Drive Forward Solenoid Error On 12-22 Auxiliary PWM Switch Out Of Range Low 50-36 Front Drive Forward Solenoid Error Off 12-23 Auxiliary PWM Switch Not In Neutral 50-37 Front Drive Reverse Solenoid Error On 13-05 Fuel Shutoff Hold Solenoid Short To Battery 50-38 Front Drive Reverse Solenoid Error Off 13-06 Fuel Shutoff Hold Solenoid Short To Ground 50-39 Rear Drive PWM Solenoid Error On 13-07 Fuel Shutoff Hold Solenoid Open Circuit 50-40 Reverse Drive Coil Short To Battery 14-02 Fuel Shutoff Pull Solenoid Error On 50-41 Rear Drive PWM Solenoid No Signal 14-03 Fuel Shutoff Pull Solenoid Error Off 50-42 Rear Drive PWM Solenoid Not Calibrated 18-05 Spool Lock Short To Battery 50-43 Rear Drive Forward Solenoid Error On 18-06 Spool Lock Short To Ground 50-44 Rear Drive Forward Solenoid Error Off 18-07 Spool Lock Open Circuit 50-45 Rear Drive Reverse Solenoid Error On 20-02 Two Speed Error On 50-46 Rear Drive Reverse Solenoid Error Off 20-03 Two Speed Error Off 50-47 Two Speed Error Off 21-02 Glow Plug Error On 50-48 Two Speed Error On 21-03 Glow Plug Error Off 50-49 Brake Solenoid Error On 22-02 Starter Error On 50-50 Brake Solenoid Error Off 22-03 Starter Error Off 50-51 Brake Solenoid No Signal 26-02 Front Base Output Error On 50-52 Brake Lights Short To Battery 26-03 Front Base Output Error Off 50-53 Brake Lights Short To Ground 27-02 Front Rod Solenoid Error On 50-54 Differential Lock Error On 27-03 Front Rod Solenoid Error Off 50-55 Differential Lock Error Off 28-02 Diverter Solenoid Error On 50-56 CAN Communications Fault 28-03 Diverter Solenoid Error Off 50-57 Drive Controller Not Calibrated 29-02 High Flow Solenoid Error On 50-59 Front Wheel Speed Sensor Missing Pulses 29-03 High Flow Solenoid Error Off 50-60 Remote Hydraulics Short To Battery 30-28 Controller Memory Failure 50-61 Remote Hydraulics Short To Ground 31-28 Interrupted Power Failure 50-63 Front Angle Sensor Calibration Error 33-23 Main Controller Not Programmed 50-65 Auxiliary Base Coil Short To Ground or Open Circuit 35-05 Two Speed Fan Short To Battery 50-66 Rear Angle Sensor Calibration Error 35-06 Two Speed Fan Short To Ground 50-67 Front Drive Forward No Signal 36-48 ACD Multiple Controllers Present 50-68 Front Drive Reverse No Signal 63-05 TICS Sensor Short To Battery 50-69 Rear Drive Forward No Signal 63-06 TICS Switch Short To Ground 50-70 Rear Drive Reverse No Signal 64-05 Switched Power Relay Short To Battery 50-72 Fan Coil Short To Ground 64-06 Switched Power Relay Short To Ground 50-74 Throttle Sensor Channel A Out Of Range Low 64-07 Switched Power Relay Open Circuit 50-75 Throttle Sensor Channel B Out Of Range High 65-05 Workgroup Lockout Solenoid Short To Battery 50-76 Throttle Sensor Channel B Out Of Range Low 65-06 Workgroup Lockout Solenoid Short To Ground 50-77 Auxiliary Diverter Error On 65-07 Workgroup Lockout Solenoid Open Circuit 50-78 Auxiliary Diverter Error Off 67-05 Bobtach Short To Battery 50-80 PTO Speed Sensor Out Of Range High 67-06 Bobtach Short To Ground 50-81 PTO Speed Sensor Out Of Range Low 69-05 Operator Presence Relay Short To Battery 50-82 PTO Speed Sensor Open Circuit 69-06 Operator Presence Relay Short To Ground 50-99 In Calibration Mode 69-07 Operator Presence Relay Open Circuit Toolcat Display Controller Toolcat Drive Controller Updated June 2009 VersaHANDLER XX‐XX CODES Code Description Code Description 02-16 Hydraulic Charge Filter Not Connected 50-02 Extend / Retract Control Out of Range High 02-17 Hydraulic Charge Filter Plugged 50-03 Extend/Retract Control Out of Range Low 03-09 Battery Voltage Low 50-04 Extend/Retract Control Not In Neutral 03-10 Battery Voltage High 50-05 Auxiliary Control Out of Range High 03-11 Battery Voltage Extremely High 50-06 Auxiliary Control Out of Range Low 03-14 Battery Voltage Extremely Low 50-07 Auxiliary Control Not In Neutral 03-15 Battery Voltage in Shutdown 50-14 Inching Control Out of Range High 03-22 Battery Voltage Out of Range Low 50-15 Inching Control Out of Range Low 04-14 Engine Oil Pressure Extremely Low 50-16 Inching Control Not Calibrated 04-15 Engine Oil Pressure in Shutdown 50-20 Boom Pressure Out Of Range High 06-10 Engine Speed High 50-21 Boom Pressure Out Of Range Low 06-11 Engine Speed Extremely High 50-23 Drive Controller Not Programmed 06-13 Engine Speed No Signal 50-24 Stability Valve Error On 06-15 Engine Speed In Shutdown 50-25 Stability Valve Error Off 06-18 Engine Speed Out of Range 50-26 Interrupted Power 07-10 Hydraulic Oil Temperature High 50-28 FNR No Inputs Active 07-11 Hydraulic Oil Temperature Extremely High 50-29 FNR More than One Input Active 07-15 Hydraulic Oil Temperature In Shutdown 50-30 Rear Light Relay Error On 07-21 Hydraulic Oil Temperature Out Of Range High 50-31 Rear Light Relay Error Off 07-22 Hydraulic Oil Temperature Out Of Range Low 50-33 Passive Brake Valve Error On 08-10 Engine Coolant Temperature High 50-34 Passive Brake Valve Error Off 08-11 Engine Coolant Temperature Extremely High 50-36 Brake Light Relay Error On 08-15 Engine Coolant Temperature In Shutdown 50-37 Brake Light Relay Error Off 08-21 Engine Coolant Temperature Out Of Range High 50-42 Secondary Auxiliary Hydraulic Valve Error On 08-22 Engine Coolant Temperature Out of Range Low 50-43 Secondary Auxiliary Hydraulic Valve Error Off 09-21 Fuel Level Out Of Range High 50-45 Extend/Retract Base Error On 09-22 Fuel Level Out Of Range Low 50-46 Extend/Retract Base Error Off 13-05 Fuel Shutoff Hold Solenoid Short To Battery 50-48 5 Volt Sensor Supply 1 Out Of Range Low 13-06 Fuel Shutoff Hold Solenoid Short To Ground 50-49 5 Volt Sensor Supply 1 Out Of Range High 13-07 Fuel Shutoff Hold Solenoid Open Circuit 50-50 5 Volt Sensor Supply 2 Out of Range Low 14-02 Fuel Shutoff Pull Solenoid Error On 50-51 5 Volt Sensor Supply 2 Out of Range High 14-03 Fuel Shutoff Pull Solenoid Error Off 50-54 Switched Battery Over Voltage 21-02 Glow Plug Error On 50-55 Switched Battery Under Voltage 21-03 Glow Plug Error Off 50-56 CAN Communication Fault 22-02 Starter Error On 50-57 Drive Controller Not Calibrated 22-03 Starter Error Off 50-58 CAN RPM Message Stale 30-28 Controller Memory Failure 50-60 Drive Pump Forward Error On 31-28 Interrupted Power 50-61 Drive Pump Forward Error Off 33-23 Constant Data Not Calibrated 50-63 Drive Pump Reverse Error On 36-48 ACD (Attachment Control Device) Multiple Controllers Present 50-64 Drive Pump Reverse Error Off 63-05 Operator Presence Sensor Short To Battery 50-66 Extend/Retract Rod Error On 63-06 Operator Presence Sensor Short to Ground 50-67 Extend/Retract Rod Error Off 64-05 Switched Power Relay Short To Battery 50-69 Auxiliary Hydraulics Base Error On 64-06 Switched Power Relay Short To Ground 50-70 Auxiliary Hydraulics Base Error Off 64-07 Switched Power Relay Open Circuit 50-72 Auxiliary Hydraulics Rod Error On 65-05 Joystick Lockout Short To Battery 50-73 Auxiliary Hydraulics Rod Error Off 65-06 Joystick Lockout Short To Ground 50-78 Boom Float Relay Error On 65-07 Joystick Lockout Open Circuit 50-79 Boom Float Relay Error Off 70-28 Brake Pressure Failure 50-80 Two Speed Relay Error On 77-48 Key Switch Multiple 50-81 Two Speed Relay Error Off 50-82 EEPROM Error VersaHANDLER Display Controller VersaHANDLER Drive Controller Update June 2009
I changed out the 25 amp fuse even thought the old one looked ok. I don't have a cab door and don't think I have the 7 pin connector by aux coupler. Just started it up and let run for a little while. The 41-09 code will come on then go off still. Maybe on for a minute or less before it goes off. But then in about another minute it comes back on.
I saw something on another thread about the reverse switch causing problems with charging. So I am trying to trace my wires to see if I have any obvious bad spots. I notice that I have three connectors under the seat in one harness that are not connected to anything. I trace them back to what I believe are the reverse switches. I knew that they had unhooked the back up alarm, but did they do it correctly, or could this contribute to my problem?
So I finally had time to start tracing wires. Found my problem right away. While running my hand back to the alternator, I pulled the wire a little and came free. The charging wire at the alternator post had broke off the connector. But since the alternator an wiring are in such a difficult place to get to, I hadn't noticed it when I changed the alternator. I so miss the old New Holland. You could remove the sides and see what you needed to fix.
