Some hydraulic issues - MD70
roblarss
My loader had all the hydraulic lines to the loader spool off when I bought it. I got all the lines figured out but I have one extra that I cant figure out where to hook up. Does anyones loader have 2 lines that are connected together at one of the spool ports? Everything seems to work. loader up/down, curl in/out, grapple open/close. The curl in is fast but curl out is very slow unloaded. If dumped with load then the bucket will flop up if pushed on ground gently. Has no pressure on other side until you hold the controls for 30 seconds Grapple opens fast but not as fast closing and seems to lack a bit of power when closing. When I got it I just used trial and error to figure where the lines all go since I cant follow them once they go into the engine compartment. Have used it all summer like this so far. Thanks
