server error
glenbell
G
Server Error in '/' Application.
'/files/file[@name='Frank's Bobcat 763']/description' has an invalid token.
[FONT=Arial, Helvetica, Geneva, SunSans-Regular, sans-serif]Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Xml.XPath.XPathException: '/files/file[@name='Frank's Bobcat 763']/description' has an invalid token.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
Code:
[XPathException: '/files/file[@name='Frank's Bobcat 763']/description' has an invalid token.]
   System.Xml.XPath.XPathParser.ParseStep(AstNode qyInput) +532
   System.Xml.XPath.XPathParser.ParseRelativeLocationPath(AstNode qyInput) +12
   System.Xml.XPath.XPathParser.ParseRelativeLocationPath(AstNode qyInput) +105
   System.Xml.XPath.XPathParser.ParseLocationPath(AstNode qyInput) +68
   System.Xml.XPath.XPathParser.ParsePathExpr(AstNode qyInput) +140
   System.Xml.XPath.XPathParser.ParseUnionExpr(AstNode qyInput) +22
   System.Xml.XPath.XPathParser.ParseUnaryExpr(AstNode qyInput) +81
   System.Xml.XPath.XPathParser.ParseMultiplicativeExpr(AstNode qyInput) +22
   System.Xml.XPath.XPathParser.ParseAdditiveExpr(AstNode qyInput) +22
   System.Xml.XPath.XPathParser.ParseRelationalExpr(AstNode qyInput) +22
   System.Xml.XPath.XPathParser.ParseEqualityExpr(AstNode qyInput) +22
   System.Xml.XPath.XPathParser.ParseAndExpr(AstNode qyInput) +17
   System.Xml.XPath.XPathParser.ParseOrExpr(AstNode qyInput) +17
   System.Xml.XPath.XPathParser.ParseXPathExpresion(String xpathExpresion) +55
   System.Xml.XPath.XPathNavigator.Compile(String xpath) +55
   System.Xml.XPath.XPathNavigator.Select(String xpath) +30
   DotNetNuke.GalleryXML.Description(String FileName) in N:\BobcatDNN\Components\TTTGalleryXML.vb:79
   DotNetNuke.GalleryFolder.Populate() in N:\BobcatDNN\Components\TTTGalleryObjects.vb:430
   DotNetNuke.GalleryUtility.PopulateAllFolders(GalleryFolder rootFolder) in N:\BobcatDNN\Components\TTTGalleryUtility.vb:155
   DotNetNuke.GalleryConfig..ctor(Int32 ModuleID) in N:\BobcatDNN\Components\TTTGalleryConfig.vb:439
   DotNetNuke.GalleryConfig.GetGalleryConfig(Int32 ModuleID) in N:\BobcatDNN\Components\TTTGalleryConfig.vb:175
   DotNetNuke.BaseGalleryRequest..ctor(Int32 ModuleID) in N:\BobcatDNN\Components\TTTGalleryRequest.vb:320
   DotNetNuke.GalleryRequest..ctor(Int32 ModuleID) in N:\BobcatDNN\Components\TTTGalleryRequest.vb:95
   DotNetNuke.TTT_Gallery.Page_Load(Object sender, EventArgs e) in N:\BobcatDNN\DesktopModules\TTTGallery\TTT_Gallery.ascx.vb:73
   System.Web.UI.Control.OnLoad(EventArgs e) +67
   System.Web.UI.Control.LoadRecursive() +35
   System.Web.UI.Control.LoadRecursive() +98
   System.Web.UI.Page.ProcessRequestMain() +750
[/FONT]
Version Information: Microsoft .NET Framework Version:1.1.4322.2300; ASP.NET Version:1.1.4322.2300[/FONT]
etting the following error message when trying to access the photo section:
