Bobcat Skidsteer Forums
parking brake won't release on Bobcat 553
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 102552" data-attributes="member: 82"><p>I'd trace the momentary wire back to the relay. If you have hold but not pull, it has to be there somewhere.</p><p>Sadly, i don't remember the colour codes for the wires. Pink white does ring a bell, i'd look for thicker wires that feed the brake. As this is the pull wire that you need, it has to handle higher current. It may help locate it.</p></blockquote><p></p>
[QUOTE="Tazza, post: 102552, member: 82"] I'd trace the momentary wire back to the relay. If you have hold but not pull, it has to be there somewhere. Sadly, i don't remember the colour codes for the wires. Pink white does ring a bell, i'd look for thicker wires that feed the brake. As this is the pull wire that you need, it has to handle higher current. It may help locate it. [/QUOTE]
Verification
Post reply
