Other Brand Skidsteer Forums
Mustang Skidsteer Forum
Mustang 920 Skid Steer, Drive Motor
Reply to thread
Message
<blockquote data-quote="canucklehead" data-source="post: 115129" data-attributes="member: 20074"><p>sounds like we are having similar issues on slightly different models. I have a Mustang 960. Left drive seemed to seize up. Primary chain master link had come off so I replaced all 4 chains on both left and right, re-assembled and left side still not working. I think the drive motor is the issue. Guessing parts will be hard to get. What did you do to find what you needed to replace/repair motor? How long did it take to remove motor? Did you have to remove the main pump assembly under seat to have enough room to pull out the left motor? I think the right side motor is further ahead so you don't have to pull main pump motor. I am so frustrated with this I am thinking of taking to a shop to do it. How many hours should this take? Sorry for all the questions and thanks for your help.</p></blockquote><p></p>
[QUOTE="canucklehead, post: 115129, member: 20074"] sounds like we are having similar issues on slightly different models. I have a Mustang 960. Left drive seemed to seize up. Primary chain master link had come off so I replaced all 4 chains on both left and right, re-assembled and left side still not working. I think the drive motor is the issue. Guessing parts will be hard to get. What did you do to find what you needed to replace/repair motor? How long did it take to remove motor? Did you have to remove the main pump assembly under seat to have enough room to pull out the left motor? I think the right side motor is further ahead so you don't have to pull main pump motor. I am so frustrated with this I am thinking of taking to a shop to do it. How many hours should this take? Sorry for all the questions and thanks for your help. [/QUOTE]
Verification
Post reply
