Bobcat Skidsteer Forums
Melroe 500 steering issues
Reply to thread
Message
<blockquote data-quote="foton" data-source="post: 107372" data-attributes="member: 16041"><p>ok I do not know if you have one but I bought the shop manual on cd off ebay so if you do not have it maybe I can check out questions that you might have when you get in it. I was told by a bobcat mech. that it is obvious when you open them up , I was told be careful with the needle bearings they are in cages but must be positioned back right. He also said that if it has had oil at the right levels in the past the bearings ( needle and thrust) should be good.</p></blockquote><p></p>
[QUOTE="foton, post: 107372, member: 16041"] ok I do not know if you have one but I bought the shop manual on cd off ebay so if you do not have it maybe I can check out questions that you might have when you get in it. I was told by a bobcat mech. that it is obvious when you open them up , I was told be careful with the needle bearings they are in cages but must be positioned back right. He also said that if it has had oil at the right levels in the past the bearings ( needle and thrust) should be good. [/QUOTE]
Verification
Post reply
