Bobcat Skidsteer Forums
gehl 2600 hydraulic issue
Reply to thread
Message
<blockquote data-quote="mike_belben" data-source="post: 100876" data-attributes="member: 14096"><p>Im not at all familiar with your gehls setup. Im picturing a belt coupled to the entire pump drive.. Meaning 3 pumps in tandem .. Two high pressure steer pumps and a gear or vane pump at the end that probably provides loader fluid and charge pressure for the drive pumps. A loose drive belt would definitely not help anything and should be addressed immediately before you shred it and tear stuff up via shrapnel.</p></blockquote><p></p>
[QUOTE="mike_belben, post: 100876, member: 14096"] Im not at all familiar with your gehls setup. Im picturing a belt coupled to the entire pump drive.. Meaning 3 pumps in tandem .. Two high pressure steer pumps and a gear or vane pump at the end that probably provides loader fluid and charge pressure for the drive pumps. A loose drive belt would definitely not help anything and should be addressed immediately before you shred it and tear stuff up via shrapnel. [/QUOTE]
Verification
Post reply
