Cat 287b Track loader hydraulic problem
bmanlyo
My right track will not rotate forward or reverse. My boom & bucket works (raises, lowers, tilts ).The left track rotates fine. Any suggestion on how to trouble shoot the right drive? Thier are 2 big hoses and 2 small hoses can anyone explain which does what and how to test with a gauge? Thanks
I had the same problem, how many hrs?? big ones are your main flow should have 5000 psi the other 2 is a break I believe. I would first check your hydro oil filter see if theres any brass cut it open. next best thing check your relief valves on the pump.
Did you you figure out what it was? Mine is doing the same thing.
