Other Brand Skidsteer Forums
Case Skidsteer Forum
Case 1740 variable speed pulley
Reply to thread
Message
<blockquote data-quote="MTHJim" data-source="post: 78919" data-attributes="member: 11330"><p>I have the 1740 and the piston for the pulley has snapped off from inside at the threaded portion. The piston was not in service for some time as the previous owner had disconnected the hydraulic line to it. I figured the fluid coupler failed so they just removed the feed and capped the valve. I use this around our small farm and have had to make many repairs but this one seems daunting, It appears the transmission needs removed to access the pulley and not sure if I can extract the threaded section. Any help is appreciated including parts sources. Thank you, Jim</p></blockquote><p></p>
[QUOTE="MTHJim, post: 78919, member: 11330"] I have the 1740 and the piston for the pulley has snapped off from inside at the threaded portion. The piston was not in service for some time as the previous owner had disconnected the hydraulic line to it. I figured the fluid coupler failed so they just removed the feed and capped the valve. I use this around our small farm and have had to make many repairs but this one seems daunting, It appears the transmission needs removed to access the pulley and not sure if I can extract the threaded section. Any help is appreciated including parts sources. Thank you, Jim [/QUOTE]
Verification
Post reply
