Bobcat Skidsteer Forums
bobcat 645 leaking from seals
Reply to thread
Message
<blockquote data-quote="tom18287@AOL.COM" data-source="post: 110273" data-attributes="member: 5183"><p>not sure about the connectors, they are most likely automotive connectors, and as long as you replace both sides of the connector you can use any style. by the way, did you replace the u-joint while you have the engine out?</p></blockquote><p></p>
[QUOTE="tom18287@AOL.COM, post: 110273, member: 5183"] not sure about the connectors, they are most likely automotive connectors, and as long as you replace both sides of the connector you can use any style. by the way, did you replace the u-joint while you have the engine out? [/QUOTE]
Verification
Post reply
