Bobcat Skidsteer Forums
bobcat 310
Reply to thread
Message
<blockquote data-quote="Hotrod1830" data-source="post: 105137" data-attributes="member: 4331"><p>The low speed pulley is around 5.4", the high speed is around 6.9. they where originally wired to a 5 pin relay with low speed on pin 87A, high speed on pin 87 and activated with a momentary button on the left handle. high speed is usually only used for travel or really light work, the high speed pulley was closest to the engine one the shaft, and bolted to the closure plate, the low speed was the outer and used a bracket to hold the base and wiring. I have a picture of my old 310 on here, you should be able to see it.</p></blockquote><p></p>
[QUOTE="Hotrod1830, post: 105137, member: 4331"] The low speed pulley is around 5.4", the high speed is around 6.9. they where originally wired to a 5 pin relay with low speed on pin 87A, high speed on pin 87 and activated with a momentary button on the left handle. high speed is usually only used for travel or really light work, the high speed pulley was closest to the engine one the shaft, and bolted to the closure plate, the low speed was the outer and used a bracket to hold the base and wiring. I have a picture of my old 310 on here, you should be able to see it. [/QUOTE]
Verification
Post reply
bobcat 310
