Other Brand Skidsteer Forums
Case Skidsteer Forum
Aux. foot pedal, backhoe only works when left side of pedal is pushed
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 108405" data-attributes="member: 82"><p>Leaks come over time, the older the machine, more leaks you get.</p><p>If the ther controls are good speed, and only the side to side is the issue, you put a restrictor in a fitting. If you have gear, you can take out a fitting to the cylinder, weld up the hole and drill a smaller one, sizes are just trial and error. Others have installed washers, but i am not sure where you can do this and not have them move around.</p></blockquote><p></p>
[QUOTE="Tazza, post: 108405, member: 82"] Leaks come over time, the older the machine, more leaks you get. If the ther controls are good speed, and only the side to side is the issue, you put a restrictor in a fitting. If you have gear, you can take out a fitting to the cylinder, weld up the hole and drill a smaller one, sizes are just trial and error. Others have installed washers, but i am not sure where you can do this and not have them move around. [/QUOTE]
Verification
Post reply
