ASV RC60 Charging system
tmstew1
I'm working on a ASV RC60 ALT was bad so I replaced it now it still does not charge unless I pull the diode and put it back in the fuse box. I also replaced the diode looking for any idea's
Is it possible you have diode installed reversed?
yes I do know that I tried the diode both ways and when you reverse it the machine would not shut off. I ran more tests today and found when the guy who owns the machine he put the small wire on the wrong post I found that there was only 7.11 volts going through the diode the checked the power at the alt and the post feeding the diode side was on the wrong post. Changed post and now its working fine. thanks for the help
