Bobcat Skidsteer Forums
763 fuel pickup tube locate & replace
Reply to thread
Message
<blockquote data-quote="Jake" data-source="post: 25091" data-attributes="member: 2444"><p>For future readers with a 763, access to the fuel pick up tube is awkward but not that bad. 2 bolts to Lift the cab Throw in some carpet scraps on top of the chain case for padding Crawl in on your belly - take a piece of thick foam rubber for a head rest The pick up tube is behind the hydro motor - right side Use needle nose pliers,,,maybe vise grips and a flat bar Tube with bullet plug came out easily & reinstall was reasonably easy In my case the screen on the end of the pick up tube was blocked up....I simply used gas and a tooth brush to clean it. Presto - all is well! Thanks Tazza for your reply.</p></blockquote><p></p>
[QUOTE="Jake, post: 25091, member: 2444"] For future readers with a 763, access to the fuel pick up tube is awkward but not that bad. 2 bolts to Lift the cab Throw in some carpet scraps on top of the chain case for padding Crawl in on your belly - take a piece of thick foam rubber for a head rest The pick up tube is behind the hydro motor - right side Use needle nose pliers,,,maybe vise grips and a flat bar Tube with bullet plug came out easily & reinstall was reasonably easy In my case the screen on the end of the pick up tube was blocked up....I simply used gas and a tooth brush to clean it. Presto - all is well! Thanks Tazza for your reply. [/QUOTE]
Verification
Post reply
