Bobcat Skidsteer Forums
743 Stalling
Reply to thread
Message
<blockquote data-quote="Tazza" data-source="post: 25334" data-attributes="member: 82"><p>It will be engine oil at the throttle lever, don't be too worried about that.</p><p>Now the fuel issue, this is what i would do:</p><p>Lift the cab, find the fuel pickup tube on the fuel tank, pull it out. Replace the tube and ensure the screen is CLEAN at the bottom, its not really needed as all the fuel runs through a filter anyway. You may even want to ensure your lift pump is good as well.</p><p>The fuel supply on these machines is very simple. Ensure the bleed screw is tight too on the injector pump. If its left open after priming it will cause all sorts of running issues.</p><p>Hopefully that will give you a starting point.</p></blockquote><p></p>
[QUOTE="Tazza, post: 25334, member: 82"] It will be engine oil at the throttle lever, don't be too worried about that. Now the fuel issue, this is what i would do: Lift the cab, find the fuel pickup tube on the fuel tank, pull it out. Replace the tube and ensure the screen is CLEAN at the bottom, its not really needed as all the fuel runs through a filter anyway. You may even want to ensure your lift pump is good as well. The fuel supply on these machines is very simple. Ensure the bleed screw is tight too on the injector pump. If its left open after priming it will cause all sorts of running issues. Hopefully that will give you a starting point. [/QUOTE]
Verification
Post reply
743 Stalling
