Other Brand Skidsteer Forums
John Deere Skidsteer Forum
260 Series 2 Hydraulic System
Reply to thread
Message
<blockquote data-quote="kroog" data-source="post: 104892" data-attributes="member: 1996"><p>Deere's plus 50 is regular 10W30 oil. If you use it in your hydraulic system, any reputable 10W30 will work fine. I have a Deere 318D that uses 10W30 oil in the hydraulic system and have had zero problems with it. My previous machine (Thomas T243HDS) also used 10W30. Unless you live in a warm climate year-round, I would use the 10W30. The typical service interval is 1000 hrs for hyd system vs 200 hrs for engine due to the hyd system doesn't have combustion byproducts. I prefer machines that use engine oil vs 10W hyd oil due to cost savings and availability. If you feel you need to "take it up a notch" you could use synthetic 10W30-cleaner base stock and better viscosity charateristics. Just my 2 cents.</p></blockquote><p></p>
[QUOTE="kroog, post: 104892, member: 1996"] Deere's plus 50 is regular 10W30 oil. If you use it in your hydraulic system, any reputable 10W30 will work fine. I have a Deere 318D that uses 10W30 oil in the hydraulic system and have had zero problems with it. My previous machine (Thomas T243HDS) also used 10W30. Unless you live in a warm climate year-round, I would use the 10W30. The typical service interval is 1000 hrs for hyd system vs 200 hrs for engine due to the hyd system doesn't have combustion byproducts. I prefer machines that use engine oil vs 10W hyd oil due to cost savings and availability. If you feel you need to "take it up a notch" you could use synthetic 10W30-cleaner base stock and better viscosity charateristics. Just my 2 cents. [/QUOTE]
Verification
Post reply
