mikeyTexas
- Joined
- Feb 9, 2026
- Messages
- 1
Have a bobcat s300, let it run low on diesel and it sucked up some nasty looking trash. Now the filter is clogged with this sticky thick tar substance that the diesel will not move it or break it down. So I've replaced the fuel filter. The fuel looks a lot cleaner now, but the injection pump is receiving fuel but it 4 outlets at the top are not putting out. Does anybody know we in the pump would that bad fuel clogged up or where I could look. Also is there anything I can put in it to help it out? I'm thinking I'll have to remove the injection pump tear it apart and clean it and put it back together. God please have your inputs thank you
Picture #1 - is the fuel filter I pulled out showing all the sticky tar stuff on the outside of the can.
Picturre #2. - this is the fuel I pulled out of the fuel filter. And you can see the separation at the bottom.
