mike11
- Joined
- Nov 26, 2025
- Messages
- 96
Guy hopefully you can help me out here and please be patient with my lack of familiarity with this unit at the moment. I’m no expert on this machine yet. Here’s the story on it I recently picked this machine up, seller said it needs wiring work, ok. Well it does alright! Someone removed ALL boss and aux wiring and controllers, installed a non boss harness with analog gauges, which will run the machine but I want the aux hyd to work like they’re supposed to. So I purchased the correct controller for the machine, I’m going to most likely have to build a harness for it, now while looking at the schematics, there are 2 variations of the wiring,
1 with front aux valve control harness and
1 without
Which would be correct ? I also need to ID 2 valves, each is along the main frame behind the controls up under there.
The schematic says I must wire to front aux rod sol and front aux base sol, could someone please point me to where they are.
It looks like there was a horrible Frankenstein job to make the aux work in the past but it looks like it was never finished and that person can not be contacted so I’m starting from scratch.
As far as gauges go I’m putting a few in with senders which will be fine. I do how ever need to get a plug onto the sender plug for the fuel tank, is that accessible without removing the engine ???
Thanks for all your help and insight
1 without
