I pulled this from my John Deere 170 skid steer. It wasn't the original engine. It did run, but not well. The top end was worn, bad rings etc from the previous owner not having an air cleaner on it. Some of the plugs were firing intermittently which could just be a worn ignition system. I couldn't get to the plugs or distributor with the engine in the machine so instead of removing it and fixing a few problems, I just picked up another engine, put electronic ignition on it, new wires and plugs, and just swapped engines to be done all at once. The starter is bad, there's no carb, I used it on the other engine, no coil, I think I used the distributor cap, and those gauges too. no fuel pump, it's basically a long block. I will part it out if theres interest and ship as cheap as I can(USPS flat rate if possible), the heads, manifold, crank, etc. I'm in Virginia 22650
