TL 150
CSG
Does anyone know a place that sales Takeauchi parts. When you back up the right track sticks. Someone said it might be a hydrostat pump. Does this sound right?
It could be the drive motor too. SOmetimes you can swap them from side to side and see if the problem moves.
As you say track, i assume this is a tracked machine? if so, the sticking could be from the reuction box, a part of a gear could be floating around sticking between other teeth. If this is the case, you need to get into it sooner than later. The longer it goes on, the more damage it will do.
