takeuchi tl150
auto107
i have a take tl150 that keep shutting down after 15 sec with the oil press and coolant level light on. does the detent and auxil switch has anything to do with this ? coolant and oil is good
I guess it could be a bad oil pressure or coolant level/temperature sender.
sandhills-elect
Look in your manual but i am sure they have protection built in if you loose coolant or engine oil it will shut down. Sure it will be bad sensor if level are right as tazzas said. Good luck Brent.
goose
Check your coolant level. There is a switch in one of the radiator hoses that will shut it down if the engine is low on coolant. If the coolant level is OK you can bypass the switch to see if it will run before you buy a new switch.
