sv300
Jeffrey
sv300
my machine sv300 set code 1203 , have case book with 16 pages of codes not 1203
starts runs fine hydraulics work , but moving in high or low jerks if i isolate each joy stick same issue
battery voltage was low 11.7 volts charged( externally) to 12.5 volts same issue alternator inoperative ordered new one
has any one had this issue ? do you think alternator will fix ??
thanks
foton
with electrics running everything that alt. must put out correct voltage for the computer to work correctly. get it replaced and see first. did you have anyone load check alt.? If you ordered a new one and a core is not required I would have that old one rebuilt and store away for the next time.
