S185 starts and then shuts down
jgodd
I start my bobcat and then it beeps three times and shuts down. Give the general warning light cannot read codes lcd display does not show all numbers. Can someone give me an idea of what is wrong
Tlawdogg
A complete Shot in the dark: fuel shut off solenoid valve ?
Hopefully an expert on that will chime in soon..
Todd
From another post same issue: Running for only a few seconds makes me suspect the fuel shut off solenoid, if the hold coil is not working, it will start but when the pull coil de-enerizes it will shut off.
mocus250
I had that issue and it was discharged battery due to fuse /relay coming out of socket below the seat causing alternator to not charge
