Mounting a tank to the outside of the frame is a little risky as it is exposed.Second question was the configuration of the fuel 'up take' tube. It is simply a steel tube welded at the top and ends about an inch short of the bottom of the tank. Any rust holes or cracks will suck air and no fuel will be available below that point. He tells me there is a simple way to remedy this. He drills a hole in the fuel tank about one inch above the bottom of the tank, places a (fine thread) elbow in the hole connected to a steel tube up to the (electric) fuel pump. He welds a stud or two to the body to support the steel tube from vibration.
How weird of a shape is the fuel tank? is it possible to get one made out of sheet metal?
