I've decided to sell it for $5000 cash this weekend. If it doesn't sell on craigslist...I've found someone on dieselenginetrader.com called mdb aircool, they will take my engine, rebuild it, send it back for $4250. Thats everything. He said if it doesn't need a new crank or things like that...like my injectors because I already replaced them...it will be cheaper. I'm thinking I'll go this route. Only question I have is what else major could be wrong. Some of those hydraulic pumps and valves seem pretty complex. I am a little concerned that it isn't driving straight. I don't have the same steering system as I saw on here where the cams wear out. I've got linkages to ball joints on the hydro pumps. I can push the port lever forward all the way and it creeps, stbd I must barely push forward or it goes left quickly. Port goes reverse very quickly, as stbd needs pulled a bit more. Sounds like a bit out of adjustment, and I am reading up on it. How would I do a good check of the chains, and drive belt before I dig toooooooo far into this with a new engine? Ant told me the chain check I think....any other things you'd look at. I'm looking at about $9000 into 1996 863C series with a fresh engine with 0 hours on it, newer bucket , and decent tires....What do you think? Worth $10000 if I wanted to sell it? Thanks for all your help guys!
