older threads
jerry
Owensge, this is what I run into when I try to go back on some of the older threads. This one is from a thread titled "lapping wear plates", it usually happens on the second or third page. It makes no difference whether I use internet explorer or firefox. Thank you. I am not having any luck trying to make paragraphs or getting this to appear in its original form. Server Error in '/' Application. -------------------------------------------------------------------------------- Input string was not in a correct format. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code. Exception Details: System.FormatException: Input string was not in a correct format. Source Error: An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below. Stack Trace: [FormatException: Input string was not in a correct format.] System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) +0 AspNetForums.Controls.Paging.PrevNext_Click(Object sender, EventArgs e) +57 System.Web.UI.WebControls.LinkButton.OnClick(EventArgs e) +108 System.Web.UI.WebControls.LinkButton.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String eventArgument) +57 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +18 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +138 System.Web.UI.Page.ProcessRequestMain() +1292 --------------------------------------------------------------------------------
