older diesel kubota bobcat 751 for sale
mmsllc
ok.....this machine was used for concrete removal, but has a newer engine in it. it always starts right up every time. the ONLY issue it has is the arms will not lower while the engine is running. you have to turn the machine off & use the hyd release valve to lower the arms that way. WHAT HAD HAPENED WAS.....we removed the main control valve to reseal it & something got knocked loose in between the valve halves. As far as condition goes, it might be a great parts machine. The bucket is stuck on the bob-tach because it was no removed often enough to grease up the locking pins slides. There is probably slop in the bob-tach pivot pins too. Beyond that, it was a good solid, very strong machine. Make your very best offer & I will probably take it. keep in mind it is still a diesel engine Kubota with a hell of life left in it.
