The lower cooler hose that runs from the foot operated controller has worn through and needs to be replaced. I have already read tfm and it pretty much says just replace the hose so not much help there. There is only a small hole beneath the radiator where you can see the fitting. I can barely get a wrench on it and can't get it to turn at all. Don't want to try too hard and bust the tank fitting off. If anyone has any experience with this could you give me a hint. Looks like either go in by removing the radiator and shroud or possibly go through the bottom but then I would have to remove the fuel tank, I think. Any ideas appreciated. Thanks
