That's a pretty good idea! In response to your earlier post. The machine has a working block heater and it was plugged in. We cycled the grid heater until it was nice and hot. I even went so far as to tarp the machine and use a space heater for a couple hours. It didn't even try to fire. No smoke either. I really think it's not getting fuel. I was able to get to the main spin-on filter and it was only half full. Maybe I have a leak and it's bleeding down? The fuel pump is working fine and it should have winter diesel. Would that also explain the hard initial cold start?
No smoke is a good indication the engine is not getting fuel. Don't worry about the cold start advance until you get these other problems corrected. The advance would still let fuel in to the injectors and the engine would smoke. You could have more than one problem going on. When you can get to the injection pump check to make sure the fuel shut off solenoid is getting power with the key on. If you have no power check that the auxillary hydrualic control handle is in the neutral position. This is the handle on top of the right steering lever. If it is then unplug the switch at the control valve auxillary spool. The power comes from the instrument panel to the auxillary control valve spool switch, then to the injection pump. With the key on you should have power to one wire of the connector. You can temporarilly install a jumper wire in the connector coming from the instrument panel.
With a half full fuel fiter it sounds like the fuel pump is not getting fuel or you have a leak in the fuel supply line. Did you bleed the fuel filter? On some engines that have had a fuel supply problem you have to loosen the injecor line nuts slightly and crank the engine to bleed the air from the injectior lines before they will start. I am not familiar with the L190 engine but the L185 engine will not start unless the injector lines are bled. I usually crack two or three injector line nuts since some may to be easilly accessable.
You do have an inline fuel filter also. Check the fuel lines from the tank to the injection pump, especially at the left rear corner of the engine, looking from the back, for places that have worn through. You will not always see fuel leaking at those places but air can leak in. Have heard of, but never seen, holes in the fuel supply tube that goes into the fuel tank.
If you have power to the fuel solenoid and the fuel system is bled and you are not getting fuel at the injectors when the line nuts are loosened then I would suspect the fuel shut off solenoid. You should hear it click when power is supplied to it.
If you can come up with the fittings you can install a clear line in the fuel supply line to the fuel pump and check for air bubble when you do get the engine started. Air bubbles in the fuel supply line can be detrimental to the injection pump.
