MUSTANG 960 cluster sprocket bearing
wolf_fav
Hello all ,
Was wonder if anyone has ever changed the bearings in the primary cluster sprocket ? Are the parts readily available? Any tips on removal?
Thanks
Firefighter
Most all parts are available. depending on serial number, some parts superseded to newer style parts
not to difficult, take t bar assembly out , remove chaincase top cover, remove connect links, remove all chains
remove cluster sprocket inner nut & outer bolt, then drive sprocket shaft out or in to remove, later version has to 2 matched bearing sets with preload rings (4) Bearings total with a spacer in the center, early version only had 2 bearings total
jannickz
Changing the bearings in the primary cluster sprocket can be a complex task, and the difficulty will depend on the specific motorcycle you're working on. But it can also be easy if you have experience.🥹:ninja:
